Max voltage safe for all electronic devices?
BobW
Green Xenon said:
Hi:
What is the maximum voltage possible *without* doing any of the following
to any extent?:
1. Exceeding the dielectric strength of any electronic component
2. Generating temperatures above 70 Fahrenheit in any electronic component
3. Ionizing any electronic component
Radium
42.
John Larkin
Hi:
following to any extent?:
2 volts maybe; tiny schottky diodes.
Millivolts can heat up milliohms.
Ionizing a component? Do you mean vaporizing it?
John
John Fields
Yup.
I thought, initially, that it was 11, but after reading your reply
and doing the necessary legwork I found that I was wrong and you
were right.
Thanks for your insight. :)
Green Xenon [Radium]
Hi:
Radium
robb
BobW said:
i think 42 just might be the ultimate answer...
but don't make a typo because it definately is not 32 , that is a
bad #, because that destroys lots of stuff
robb
Jon Slaughter
Green Xenon said:
Hi:
to any extent?:
Radium
THis is quite easy. its 0.
Don Bowey
robb
But 42 is THE answer to all questions about the Universe.
Sjouke Burry
At least it is the answer to all Radium ranti...pardon.. questions.
robb
apologies, had it backwards,
not ultimate answer but *the* answer to *the ultimate
question...*
robb
phaeton
question...*
robb
While 42 is fine and well for most situations, I've always had a
mysterious draw to 666. It has never let me down.
-phaeton
John Larkin
John said:
On Tue, 06 Nov 2007 17:40:25 -0800, "Green Xenon [Radium]"
Hi:
2 volts? Many CPUs cannot tolerate voltages above 1 volt without damage!
You said "dielectric strength."
Beyond 70 Fahrenheit?
Sure.
John
Hi:
Tom2000
-phaeton
Naw. Plug your circuit into that and all you'll get are fire and
brimstone.
John said:
Hi:
Isn't the damage to the CPU caused by a mixture of excessively high
temperatures and dielectric breakdown?
Also, dielectric breakdown [even without significant heat] damages flash
RAM chips [which is why they don't last too long]. The electrons pierce
the insulations within the chip.
How can a millivolt generate temperatures above 70 F in a milliohm? Both
the voltage and the resistance are too small to generate such high
temperatures. Right?
Paul E. Schoen
One millivolt across one milliohm is still one amp. What about several
millivolts?
Current is still V/R, so 23 (another magic number) millivolts across a one
inch length of #20 wire (about 1 mOhm) will produce 23 amps. And power is
V*I, so you have about half a watt. Doesn't sound like much, but it's
enough to melt the wire, especially if it is enclosed in thermal
insulation. If you operate a 1/2 watt lamp in a well insulated box, the air
inside will get well above 70F. Temperature depends on heat conduction and
radiation. So, imagine how hot a tiny IC bonding wire could get with just
23 mV applied to it. Pow! Er! A "semiconductor" fuse...
Paul
N
Nobody
He didn't say "a millivolt", he said "millivolts". E.g. 100mV into 1mOhm =
100A * 100mV = 10W.
A much smaller power dissipation can still produce high temperatures if
the thermal resistance is high enough.
Rich Grise
component
About 0.56V.
What do you do if the ambient is >70F?
Cheers!
Rich
About 0.56V.
Thanks.
Thats okay. I just don't want anything inside to get damaged
