MC34063/78S40 buck
Raveninghorde
I'm testing a 5V out buck converter designed around the MC34063 (cut
down 78S40). Rsc is 0.22R, the inductor 330uH and it runs at about
100kHz.
According to the data sheet I should have a peak current of under 1.5A
which is the switch transistor rating. TI say minimum Rsc is 0.2R.
At 15V in I had a short circuit current of 1.93A (on 2 samples). I
wound the supply up to 24V while measuring Isc and instant failure.
What am I missing?
TIA
Sylvia Else
100kHz.
What am I missing?
TIA
Are you sure the inductor isn't saturating?
Sylvia.
James Arthur
100kHz.
What am I missing?
TIA
Let's see...with 15v in, switch on, the inductor has ~9v across it,
current rising at 9v/330uH = 27mA/uS. Ripple current @ 1.5A load
is roughly 27mA/uS x (10uS x 5.5v/(5.5v+9v)) = 100mA.
Looks roughly okay.
100Khz looks a little fast--is there significant switch-off delay?
That would make i(L) coast past the desired limit, worsening with
higher applied voltages.
Otherwise, inductor saturation, per Sylvia.
Cheers,
James Arthur
Raveninghorde
Sylvia.
Doh!
Thanks. Chose an inductor I knew was OK and then increased the value
and didn't recheck Isat. But I knew the inductor was OK so didn't
check for that. Forgot rule 1, if you can't find the fault it's where
you're not looking.
Sylvia Else
Raveninghorde said:
I know that feeling well enough, from many occasions. Each time I vow
never to be so blind again, and each time....
Sylvia.
