MCP2200 MICROCHIP USB 2.0 to UART Protocol Converter DDR
Blunt Viscardi
Oct 17, 2023
The MCP2200 from MICROCHIP manufacturer is a DDR with USB-to-UART 1-CH 64Byte FIFO 3.3V 20-Pin SSOP. More details for MCP2200 can be seen below.
Details
The MCP2200 is a USB-to-UART (Universal Asynchronous Receiver/Transmitter) bridge controller chip developed by Microchip Technology Inc. It enables seamless communication between a USB host (like a computer) and a UART-based microcontroller or other UART-enabled devices. The MCP2200 allows easy integration of USB connectivity into various embedded systems.
Feature
USB 2.0 Full-Speed (12 Mbps) device with on-chip transceiver.
Integrated UART with baud rates from 75 bps to 1 Mbps.
GPIO (General Purpose Input/Output) pins for additional functionality.
Configurable I/O pins for various control and status purposes.
Customizable USB descriptors to provide information about the device.
Bus-powered from USB, eliminating the need for external power.
I²C™ (Inter-Integrated Circuit) protocol support for serial communication with other ICs.
Programmable EEPROM to store various configurations.
Application
USB-to-UART bridge for interfacing with UART-enabled devices.
Serial communication interface for microcontrollers and other embedded systems.
USB-based data acquisition and logging systems.
Custom USB communication solutions for various applications.
Virtual COM port (VCP) for communication with a computer.
Tian Lin
Aug 7, 2024
The equivalent product of MCP2200 is MCP6L04T-E/ST, both of which are products of Microchip Technology. It is recommended that you check the official data document before using them.
plouf1
Mar 7, 2005
26
!!! MCP2200 is USB<> serial  MCP6L04 is  AMPLIFIER NOT EVEN CLOSE
there is NO direct drop in replacement for mcp2200 , may i ask why looking for equivelant, considering that MCP2200 is still under productio?
if you need some kind of equivelant you can compare with prolific 2303 / ftdiseries, and hundrent of others usb<>Serial//
