drumsticksplinter
- Mar 28, 2010
- 17
- Joined
- Mar 28, 2010
- Messages
- 17
I've just bought a new piece of machinery for my workshop and wired it into my 3 phase power, the same way as I always do. The machine powered up and worked fine until I noticed a fault showing up on 1 of the motor drives. When reading through the fault codes is states over voltage on the main circuit. The drives are single phase 220 - 240vac and I'm in the UK with 240V single phase 415V three phase. I then measured the voltage from the individual phases to neutral and I got some really strange readings.... fluctuating anywhere from 248v to 315v?? I did some investigating and found the cable I was testing with wasn't great, it came with another machine and looks like 2 of the cores had overheated at some point. I've changed the cable now for new, which seems to keep the motor drives happy, but the voltages from the phases to neutral are still all over the place! I have tried 3 different multi meters, all with similar readings.
has anybody got any ideas what I'm missing?
