- Joined
- Dec 18, 2013
- Messages
- 5,178
I was involved in a recent thread regarding measuring the individual battery voltage of series connected cells. The original OP didn't have the experience to design or construct anything too complex, so he was looking for an off the shelf solution.
Nothing could be found so he opted for taking the battery off load periodically to check the status of the cells. So I thought I would have ago and I remember years ago reading about using a transformer. So here it is. Fig 1 showing one battery out of a set of series cells. The extra earth connection was added to keep the simulator happy. If measuring any other cell other than the one connected to 0V then this connection is omitted.
The circuit pulses a 1:1 transformer, the voltage seen across the resistor R1 is clamped by the battery voltage minus a diode drop. The output is diode biased to take into account the diode in series with the battery. I get about 50mV error, probably due to the bias current for the diode being out a bit.
You may have seen something similar before, but if not I hope you find this interesting.
Adam
Fig 1
Fig 2
Adam
Fig 1
Fig 2
