Its there any way to measure current in a circuit without actually placing the ammeter in series with the component? Mayb there is another special device that does this?
You can use a Magnetic field sensor or a Hall Effect sensor to measure DC current. If the current passes through a resistor or a diode or just a piece of wire you can measure the voltage drop across it to calculate the current!
That was real interesting, searched on google for "Hall-Effect Sensors measure dc current" and found this:
http://www.allegromicro.com/datafile/0704-015.pdf
Unfortunately I don’t have the book (at least not yet) in your link. But I have another one on this subject which I think is very informative, I hope you agree
Here is a simple project showing one way to measure current using a Hall sensor. Even if you do not want to build one of these, you can learn from the circuit and description!
