measuring floating inductor current in a truesine inverter application
Jamie Morken
I am trying to make a true sine inverter outputting 120VAC 60Hz,
and am using 200kHz for the fet switch. Also using software PWM
control with either of one or the other of these two algorithms:
method1: (uses high speed DAC)
if inductor current > voltage error, pulse off
if inductor current > current_limit, pulse off
if time > limit pulse off (limit is our max dutycycle for this PWM period)
method2: (uses high speed ADC)
Duty cycle = ((desired voltage - current voltage) * gain) - (Inductor
current * gain2)
For the current sensing I was thinking of using a hall effect sensor,
like the "S22P025S05" from Tamura,
http://parts.digikey.com/1/parts/945709-sensor-current-25a-2-5v-pcb-s22p-s22p025s05.html
which has an operating bandwidth of up to 200kHz, but this is still too
slow to do cycle by cycle current limiting unless a larger inductor is
used than is otherwise necessary for the circuit. Is there a higher
bandwidth hall sensor that could work for this?
Also I was thinking about using a current sensing resistor and then
feeding this directly into an ADC floating at the high voltage of the
120VAC, and using optoisolators on the ADC SPI interface.
Another possible way to interface to a current sensing resistor would
be to use a high common mode voltage differential amplifier, like the
AD629.
http://www.analog.com/en/prod/0,2877,AD629,00.html
What would be other good ways to measure this high frequency
floating current?
cheers,
Jamie
Paul Mathews
current * gain2)
http://parts.digikey.com/1/parts/945709-sensor-current-25a-2-5v-pcb-s...
AD629.
floating current?
cheers,
Jamie
CT.
Paul Mathews
Jamie Morken
Paul said:
current transformer, Ya I guess that gets rid of the high commom mode
voltage, and then it is just a differential measurement that is
required?
Thanks I will look into this more.
cheers,
Jamie
F
Fred Bartoli
Paul Mathews a écrit :
CT.
Paul Mathews
Simpler: if that's possible, just add a few turns winding to your
inductor. It'll give you dPhi/dt that you then integrate (can be as
simple as a lowpass RC).
Jamie Morken
That sounds like it would be the cheapest method. Since that is
integrated/filtered, will it be too slow to detect cycle
by cycle current for comparator based current limiting?
I found a high frequency current transformer, would this do the job?
http://shinhom.com.cn/pdf5/142.pdf
cheers,
Jamie
F
Fred Bartoli
Slow?
You just integrate di/dt.
The only missing info is the DC current, but you the same pb with a CT.
and under some conditions you can restore it.
Jamie Morken
Slow?
since current transformers only work for AC, and the only AC here is the
60Hz output, I don't think current transformers can work to detect the
high frequency current.
cheers,
Jamie
Jamie Morken
Jamie said:
So are there any other options to measure the ripple of a 200kHz
current?
cheers,
Jamie
Jamie Morken
Slow?
Here's the circuit I am working with and the 200kHz current waveform for
one of the output inductors:
http://rocketresearch.nekrom.com/ne...inverter/240VAC 60Hz split phase inverter.jpg
http://rocketresearch.nekrom.com/new/split phase 240VAC inverter/current waveform.jpg
The current waveform is DC at this frequency, but is AC at 60Hz.
I don't think a current transformer can work due to the fact that this
is effectively a DC current, haven't found a fast enough hall sensor for
detecting over-current, and a shunt amplifier would have to be floating
at high voltage.
cheers,
Jamie
Jim Thompson
at high voltage.
cheers,
Jamie
You can't use a clamp-on probe?
...Jim Thompson
Terry Given
current?
cheers,
Jamie
LEM DCCTs. hall-effect devices. design an AC CT that wont saturate with
the DC current.
Cheers
Terry
Terry Given
...Jim Thompson
you have some sort of floating gate-drive for the upper FETs. a current
sense resistor in the output lead(s) sits at the Source of (one or both
of) the upper FET, so there is where you can sit some circuitry to then
transfer that signal to the control circuitry. there are some current
sensing optos, but they tend to want large voltage drops (around 0.5V)
which might not be fun, depending on your power levels. of course a
small Rs, and amp and some circuitry can "fool" the optos...
Cheers
Terry
Paul Mathews
http://rocketresearch.nekrom.com/new/split phase 240VAC inverte...
at high voltage.
cheers,
Jamie
- Hide quoted text -
- Show quoted text -- Hide quoted text -
Provided that the DC doesn't saturate its core, a CT will couple the
ac component of the current to its loaded secondary. This is done all
the time. The appropriate core size and material will handle the dc
offset. -Paul Mathews
Jamie Morken
I need to measure the DC offset though for cycle by cycle current
limiting at 200kHz, the AC current is 60Hz, the DC current is 200kHz.
What about using a shunt resistor and dual rail opamp powered by a
local isolated bipolar powersupply like this one:
http://rocketresearch.nekrom.com/new/split phase 240VAC inverter/isolated bipolar supply.jpg
(thats the same kind of supply I'm using to power the floating fets,
except not bipolar)
Could even use this supply to power a floating ADC and DAC, I need about
12bits of current and voltage accuracy so I will need to get the supply
pretty smooth, which may be a problem, maybe the current transformer is
better.
cheers,
Jamie
Jamie Morken
Maybe the circuit inside would work, I guess a DC clamp on probe must be
hall based? I'm making a PCB! :)
cheers,
Jamie
Jamie Morken
except not bipolar)
better.
(forgot the flux draining coil!)
like here:
http://www.hills2.u-net.com/electron/forward.gif
cheers,
Jamie
