JB
- Jan 1, 1970
- 0
In most lighting design software available today there are user-defined or
predefined surface reflectance values for many commonly used materials and
surface finishes found in building interiors.
In typical office lighting designs the 'default' values used in the UK seem
to be 70:50:30 or 70:50:20 for Ceiling/Walls/Floor. This I suppose, is meant
to represent typical matt or satin white paint for ceilings, white or light
coloured paint on the walls, and some darker carpet for the floor.
In order to get a more accurate value for real reflectances of actual
surface finishes or materials, what instrument do you use to measure this in
the 'real-world'?
I know I can use my spectrometer with a calibrated light source and standard
certified reflectance target (like Labsphere Spectrolon etc.), but this is
not the sort of kit you want to be carrying around for casual
spot-measurements on site.
Are there any portable or handheld instruments on the market which can be
simply held against a surface to get a reading of total diffuse reflectance?
If not, I'm thinking of building one for our own use, possibly based on a
group of RGB leds or even a tungsten lightsource and a detector such as the
Taos TSL230 or TCS230.
Anyone use anything similar or have any ideas of 'homebrewed' instruments
they use in the field?
Any thoughts on this subject would be appreciated.
JB
the 'real-world'?
JB
