Measuring Skin Response
Johnny101
Jul 13, 2014
43
Hi everyone!
I am trying to measure the skin conductance, for that I found this circuit online.
upload_2015-11-5_3-5-39-png.94053
So from it what I have understood so far:
- There is a low pass active filter at first stage with cut off of 1.6 Hz and variable gain.
- The second stage is also a filter with unity gain and is biased at half the voltage supply and the first stage is biased at the output of second.
What I don't understand:
- Why is the gain variable at first stage as the Rskin chages the gain would change?
- Isn't the first stage enough?
- Can't understand the biasing of the op-amps as well.
duke37
Jan 9, 2011
5,364
I do not understand the circuit in detail but, OA1 is not a variable gain amp, it is a virtual earth low pass amplifier with variable input current derived from the skin resistance. The output voltage is input current times 1M.
OA2 takes a constant voltage and provides OA1 with an offset bias to keep it on track.
Try simulating it with spice.
