Measuring the current used in a power supply?
24Volts
Mar 21, 2010
164
hello,
I have a power supply converter that converts 120VAC to 3.3VDC at 1A.
I would like to know (without measuring with an ammeter) when I am drawing 800 milliampères or more. When 800+ milliampères are used, I want to light up a led to indicate that the power supply has attained 80% of its capacity.
How can I do this?
All circuit ideas are welcome!
Chemelec
Jul 12, 2016
291
If you want the output STABLE at 3.3 Volts,
Than Without seeing a Schematic of your power supply, it would not be possible.
True, but if you can tolerate 3.29 V it can be done.
You need a low value (say 0.01Ω) resistor and a comparator to do this. It would drop 8mV at 800mA.
Chemelec
Jul 12, 2016
291
Hi guys,
I was thinking of using the INA169 to achieve current sensing:
https://www.sparkfun.com/products/12040
the power supply I want to monitor is located at:
https://www.digikey.ca/products/en?keywords=pbo-5-s3.3
I was wondering if this would work?
Thank you for your help
Yes that will work, But Depending on the Value of the Sensing Resistor "RS", You get a Voltage Drop.
This is Basically the Same as what "BobK" Said.
And with your Power Supply, there are No Other Options.
24Volts
Mar 21, 2010
164
Ok thanks for you help!
24V
