Measuring variation in inductance
I was wondering what precautions I should take for measuring a coil's
inductance. Following some capacitive sensing approaches my idea was
to use a MCU pin for pulling a pin connected to the coil L1 HIGH and
then measuring the voltage drop across a resistor R1 in series to the
coil.
WRITEPIN+-----------o----UUUU---o--------o---------R1--------| GND
\----|<|----/ \--READPIN
By measuring the time it takes for READPIN to reach HIGH it should be
possible to calculate L1 given a known R1 value..right?
My concern is about the coil's kickback: is the parallel diode
sufficient to protect the readpin from excessive voltages ?
Jasen Betts
coil.
you've got the coil's parallel capacitance to consider too.
and the threshold that the readpin responds at may be unpredictable,
