Nice to hear from you again Ante.. ;D Yes I like to do that, but my digital tester can't simply lock on it..maybe I needs some diodes and caps on particular pins to measure it out..
You should avoid messing with the ports like that; it can cost you the motherboard. Just get 5 or 12Volts inside from a free device power connector its much safer. Don
Much nicer to connect and very easy on batteries if you are powering from one. There is also a MAXxxx number which does not use the caps. It is MAX233, if looking to get away from the caps.
Rhonn, maybe you can ask for some free samples of these other chips as well.
I have attached the data sheet for the DS275 for anyone interested in it.
