Mechanically latched solenoid?
Dirtyeggroll
Mar 5, 2022
4
New around here. Pretty ignorant to circuits and motors in general.
My goal is to engage / disengage the plunger of a solenoid with the push of a single button with no current draw in between states.
I think the simplest way to do this is with a solenoid that holds its state after the application of a voltage without the need to reverse polarity. Voltage applied (momentary) = open state. Voltage applied (momentary) again = closed state.
Thus, I am looking for a latching solenoid that can change its state with the application of same polarity voltage.
I have seen many solenoids that hold their state with a permanent magnet, but it seems they all require reversal of polarity to change state. I think it would be simple enough to have a reverse polarity solenoid achieve the end goal with a rocker switch, or with some complicated circuitry and a push button, but I am trying to simplify this as much as possible.
Any specific solenoids you are aware of that can achieve my goal? Thanks for your help.
Dirtyeggroll
Mar 5, 2022
4
The solenoid needs to be relatively small. It needs to function to actuate a rod at least 5 mm to couple two discs, sort of like a clutch. The rod is pushed through a hole that lines up between two discs so they will spin together when one disc is driven by a shaft.
I may also further develop the system for the solenoid to be the actuation mechanism for a jaw clutch.
kellys_eye
Jun 25, 2010
6,512
Strangely (or not) I've just decommissioned an electronic cat flap(!) and it has two small latching solenoids that are used to set the physical in/out movement catches. If you;re UK-based I could drop them in the post to you?
Dirtyeggroll
Mar 5, 2022
4
in US
14,270
Use a mechanism akin to the one in a ball pen?
