Microchip PIC programming question
DAFLY98
Hi, I started programming PICS not to long ago 16F84A to be exact. I knew there
were no value compares within the instruction set but now I am in need of some
compare code. I did search the net and ran across a couple using the status
reg. carry and zero bits, but I have found some problems using it. I am doing
16bit compare but I can modify 8bit compare code to work for my needs. any help
will be appreciated
W
William P.N. Smith
compare code.
"As a result of a subtract operation, the C bit is cleared to zero if
a borrow occurs, and is set otherwise."
Design With PIC Microcontrollers
John B. Peatman
Prentice Hall
ISBN 0-13-759259-0
