Microchip reading and copying data. ( how to diy manually?)
mid
Jul 13, 2018
Hi guy,
I need help to read or copy data of the microchip with the arduino or any other diy method. Is it possible to read or copy data from the flash memory of the micro controller or micro processor?
I have attached two pictures below, which i need to read data from that chip.
kellys_eye
Jun 25, 2010
6,512
You would have to remove the device from the board and install it in the appropriate socket and read the contents using the proper programmer.
To do this manually would be as good as impossible..... one wire for each address line, one for each data line so 64 individual wires? Then you have to see address 0000 and read the 32-bit word, increment to 0001 and read the next etc repeat another 65,000+ times......
