Microcontroller with both USB and Bluetooth
itsdonny
Aug 23, 2012
12
Can someone please give me some options for a microcontroller with both USB and bluetooth?
Thank you!
Don
CocaCola
Apr 7, 2012
3,635
Many micros support USB native, Bluetooth will almost certainly require an external module... Visit the Microchip and Atmel sites for a vast variety of options for example... And look into the Bluetooth modules out of Asia that can be found on Ebay and the sorts, they are a very cost effective way to implement Bluetooth...
itsdonny
Aug 23, 2012
12
Thank you CocaCola. I'm thinking of not using usb at all. The only reason I wanted to have it was so the consumer could update the device's firmware via USB. If this can be done via bluetooth then I really don't even need USB. What do you think about updating a device by bluetooth?
CocaCola
Apr 7, 2012
3,635
I have never done it but there appears to be a few bootloaders out there that are using a Bluetooth connection... USB is IMO easier and more reliable for an end user to update with though, and the cost is nil to get a chip with USB support built in vs chips that don't have it...
itsdonny
Aug 23, 2012
12
Thank you, Coca Cola. On a slightly different note would it be possible if I were to use a micro controller with USB support to just simply add a USB dongle like the following?
http://www.amazon.com/Bluetooth-Wir...d=1348210745&sr=8-3&keywords=bluetooth+dongle
Do you know if these types of bluetooth dongle require a PC or is there a way around that. Somehow these little dongles are far less expensive than regular bt modules that I've seen.
Thanks again for your help!
Don
CocaCola
Apr 7, 2012
3,635
In theory it should work, but you might very well have to write the whole communications stack from scratch to control that module... Likely a very daunting task vs a module that is designed and documented to use standard serial interfaces...
