Microcontrollers and PWM
KRe8ive
May 26, 2012
14
I am looking at making a custom LED circuit, which will involve approx 300 RGB Leds which i would like individual control of each color in each LED, meaning approx 900 individual outputs are required. Is there an easy way to do this? I have been looking at micro controllers but most of them i have seen are not suitable for something to this extent.
The load per output would be approx 20mA. The circuit has to be a common +ve, so does this mean i will have to use the likes of a Mosfet or is there such a controller that will do PWM on a -ve?
I would possibly look at running this in 4 different circuits for the 4 different areas that the LEDs will be based in, but with common control. Was looking at using DMX for control, so would have to have at least 2 different units anyway as DMX is limited to 512
I am not very advanced at electronics, just know the basics so any help would be much appreciated.
CocaCola
Apr 7, 2012
3,635
There are LED drivers specifically designed for this... You will need to obviously use several of them as I doubt you will find a single 300 LED chip ;) but they can all be controlled by a single micro and act as a single unit...
