microsoft surface pro 4 repair
spiglys
Oct 8, 2020
8
Hi guys here, I have a question can somebody identify what is the element here at microsoft surface pro 4 board and where I can get it except donor board . thanks for smart people.
14,317
Might be an oscillator/crystal. Not sure.
What makes you think this component is defect?
spiglys
Oct 8, 2020
8
I'm not sure if is defective but if i look at it it looks like burn so this only my guess
14,317
Improbable. This kind of oscillator usually doesn't overheat.
spiglys
Oct 8, 2020
8
so why it looks like burn ? is this normal ? any way to test ?
spiglys
Oct 8, 2020
8
I think you are right. i found something interesting and I think this bad guy is the problem
narkeleptk
Oct 3, 2019
78
Harald erred on that one, they are powered, so hence they can fail and cook
that looks pretty obvious from your pic :)
Looks ok to me...
Looks cracked. Doesn't necessarily mean its bad, could just be the package but its definitely suspect.
I looked a little but did not run across any sot23-6's with code of AJ8. If you find out what it is make sure to let us know !
narkeleptk
Oct 3, 2019
78
*shrug* I think its the same board with different lighting and angle.
Only TS could really tell us I guess.
sims.jpg​
dave9
Mar 5, 2017
1,191
narkeleptk
Oct 3, 2019
78
I don't know what it is, but it looks more like AJX to me.View attachment 49457
I checked X first (both with no good results) The smaller image I looked at seemed like it had some faint curves so I was leaning to 8 but this larger blown up one you are providing looks more like an X to me as well now.
spiglys
Oct 8, 2020
8
yes this is same board . @bertus you are correct this AJX thanks for smart answer, but it seams it has 4 variations under AJX chip
bertus
3,877
There is only one in the housing you have.
The others have other housing or a small x.
Bertus
spiglys
Oct 8, 2020
8
@bertus ok it means TLV3011AIDCK is the correct part. and I will attached other picture do you know what is this component because I can't find by the number of part?
