Microwave cooling fan help
Bowmeat
Feb 16, 2020
11
Hi all .my cooling fan has gone in my microwave. So I have ordered a new one but when its arrive it has 3 connections whilst the old one had 2 connections . Am I still ok to use it and which 2 connections should I use
Ylli
Jun 19, 2018
411
You're giving us zero information to go on. What microwave did it come out of? Part number of the old and replacement parts? Pictures?
Bowmeat
Feb 16, 2020
11
14,484
3 pin one is the new 1
So why would you buy a 3 pin one when the original was 2 pin ?
You still haven't said what make and model of microwave oven ?
does the old motor have an info label on it ?
Ylli
Jun 19, 2018
411
There was a thread either here or on another forum and it was determined that the third terminal on the fan motor was often used to drive the turntable motor (or was it the lamp - anyway...). The fan coil acts not only as the field for the motor but also as a transformer to reduce the voltage for the turntable motor (or lamp)
I see the motor is listed at 240 VAC. Is this going to be installed in a uWave on a 240 volt circuit? Then just measure the resistances between the three terminals, pick the 2 with the highest resistance, and hook them up.
73's de Edd
Aug 21, 2015
3,730
Sir Bowmeat . . . . . .
All right . . . . . here is the full poop.
That GALANZ motor that you received is using the larger two terminals for your t 220-240-VAC power input.
There is the smaller end terminal for an optional derived secondary voltage output from the unit if you use the center terminal and the smaller for outputting a reduced 30VAC secondary output voltage,
That is obtained autotransformer style by utilizing the motor metal framework core, the shared existing magnetic field and an internal ratiometric tap off from the total winding, to get the reduced 30VAC.
(And NO . . . if you get the two wires reversed, it won't run backwards .)
This three terminals aspect wouldn't concern you at all, in starting with a TWO terminal motor, so use the two larger terminals.
73's de Edd . . . . .
I had amnesia once . . . . or was it twice ?
14,484
Russel hobbs
since you cant be bothered to answer questions properly
from the people that are trying to help you
You have made this way harder than what it needed to be !
I'm closing the thread
Thread reopened and other posted merged into this thread
(23/02/2020)
Bowmeat
Feb 16, 2020
11
Hi all I've replaced the cooling fan in my russel hobbs microwave .chànged the 2 plug motor to a 3 plug one . But been advised that's ok . Sorry for the late reply on my previous thread which got deleted . The new fan is now working . But it only starts with a clicking noise like a relay from a car .
. Tried up pics . But no joy
Bowmeat
Feb 16, 2020
11
This all fault has been made by my missus leaving a fork in their
Bowmeat
Feb 16, 2020
11
More pics
Bowmeat
Feb 16, 2020
11
Hi all sorry for the late reply . As in uploading the pictures .it wont let me do it from my phone gallery without screen shoting and shrinking . Now the new fan has stopped working . I've been reading up on the problem but iam thinking throwing the talwol In
73's de Edd
Aug 21, 2015
3,730
Use an AC voltmeter and check across the two motor terminals to confirm that FULL AC line voltage is being there to run the unit.
Then, also pull the blade and test the running motor shaft for torque , using index finger to thumb gripping of the then naked motor shaft.
That unit should spin the multibladed fan blade easily, just being a bladed fan, considering it also is not experiencing any binding or constrictions.
ASIDE . . . . .
I saw Bowmeats information coming forth quite correct and timely . . . with one possibly only being thrown by the lower case Russel hobbs, branding .
Of which, that was being a brand that I had never " heered " of before.
Of course some people may have never " heered " of our lil' ole neighborhood store run by Stanley Marcus and his aunt Carrie Neieman . . . . . .
https://moneywise.com/a/20-outrageous-items-from-the-neiman-marcus-catalog
Man Fact . . . .
It's impossible for a man to use a stud finder . . . if having an observing audience . . . . without him initially first swinging it all around on himself and saying . . . beep - beep - BEEP - BEEP - BEEP - BEEP - BEEP !
Bowmeat
Feb 16, 2020
11
It's like the switch that turns the fan is faulty. With the clicking noise . Where would it be locateď
duke37
Jan 9, 2011
5,364
If the fault were due to a fork being left in the microwave, it is likely that the RF generator has been damaged.
The motors are maiins voltage and can be tested outside the microwave. They may not run in the microwave due to a fault elsewhere.
