Martin Evans
- Jan 1, 1970
- 0
I would guess that they might initially pack these in a minimum humidity
environment.
British, minimum humidity?
Error, does not compute
environment.
Error, does not compute![]()
Martin Evans said:British, minimum humidity?
James said:If you cant go to a gas refill station and get some nitrogen, next best
thing would maybe be get the small co2 cylinders like used for paintball,
and purge the containers with co2 gas. It will drive out all the oxygen,
which is what causes rust with water vapor. Also use the desecant to absorb
any remaining moisture.
Still nitrogen is best!
Jtt
Lostgallifreyan said:So true. Bristol regularly records >98% for days on end in the late summer
coming off the rivers and sea to the west, often saturating at >99%
even inside houses at its worst. That's the kind of thing normally
associated with rain forests, or Vietnam.
William said:"Frithiof Andreas Jensen"
Note that there's a difference between "waterproof" and
"watervaporproof". Water vapor will diffuse thru most plastics at a
very slow rate, so you need an indicator and enough desiccant to last
the 'lifetime' of the product.
Peter said:The only thing that I would not know how do, after your excellent explanation
would be to find the most cost-effective source of nitrogen gas. It would be
nice If I could buy a couple of cubic feet at Wal-Mart for $2.99. Also would
nitrogen gas be reactive with CaSO4, CoCl2 ?
(That is the composition of my "drierite" desiccant).
Bennett said:I wonder if the bag should be an electro-static bag, rather than just
plastic of some sort. That said, I've no idea whether truly air-tight
electro-static bags are available (or necessary).
