Missing Resistor Value on LCD with Microcontroller
csmith
Jul 13, 2013
4
Hi All,
I'm having trouble repiaring a PCB which contains an LCD temperature display board. It looks like there is a resistor missing from the board.
The device is a generic non-branded device (vaporizer). I tried to find the make / model by matching it up on google images, but no luck.
The part number on the LCD unit itself is ZYH-E30561-IF
The part number on the MC is EM78P259NS018J
I can't find a good datasheet for it.
I was hoping to find a whole new LCD / MC assembly, but I'm having trouble with just the standalone components.
The resistor on pin 16 is missing (R5). I can't think of when it could have come off, but there is solder on the board suggesting that something was in-fact there.
I thought of hooking up a potentiometer and using trial and error, but I wouldn't know what to test for.
Any ideas?
Obviously I should just buy a new vaporizer at this point, but this is more of a learning exercise for me.
If the three leads connected to the three resistors are for a similar purpose (driving LEDs perhaps) and the two resistors that are there have the same value, then that value would be my first try.
csmith
Jul 13, 2013
4
Thanks so much Steve, for your advice on both of my posts.
I guess there is no way to know it's function without a datasheet of the LCD. Here is something interesting though...
It looks like it may not go anywhere. I'm assuming there was a resistor there because there is solder globbed on the board. But when I trace it through the system, it ends up at a diode that was never mounted. So it doesn't look like it would go anywhere.
Do you know of anything in the manufacturing process that would result in solder globbed onto a board with no component?
I attached a pick of R5 in my original post. I've attached to this post, a picture of where it ends up. R5 connects pin 16 on the MC, to the anode of D2, which was obviously never mounted. So maybe I don't need R5 after all?
