mitsubishi television repair
MD
I have a Mitsubishi VS-60803 CRT Rear Projection HDTV unit. It has this
problem where when it powers on, the green power light flashes on, then
shuts off half a second later. No image appears on the screen. There are
also four evenly spaced clicking sounds: the first two coincide with the
flashing, and along with the third, there is a quick, high-pitched whining
sound. The clicking is coming from the vicinity of the flyback
transformer.
I've opened up the back and made a cursory check, seeing no burned or melted
parts. What further steps can I take to isolate the problem? Would it
likely be as simple as replacing the FBT?
K
kip
If you don't have the knowledge to diagnose the fault
call a TV shop who can give you an estimate.
Believe me there is NOTHING you can do.
kip
It is as simple as getting out the schematic and test equipment and
troubleshooting the tv set for the problem and effecting a proper and
safe repair. Start by trying to find out which of the many protect
circuits is shutting the tv down, then working backwards from there to
the actual fault.
Simply guessing and replacing parts can get very expensive.
Dave Moore
If it has any black Nichicon caps with the + on the top
or black Rubicon caps with the K on the top, they'll
probably all have to be replaced as they were
made with bad Chinese electrolyte and will leak
and damage adjacent components and copper
traces.
I'm going to compile a list of the the specific
"type" markings on these caps and post them
later.
Perhaps someone has already done this ?, dunno.
: I have a Mitsubishi VS-60803 CRT Rear Projection HDTV unit. It has this
: problem where when it powers on, the green power light flashes on, then
: shuts off half a second later. No image appears on the screen. There are
: also four evenly spaced clicking sounds: the first two coincide with the
: flashing, and along with the third, there is a quick, high-pitched whining
: sound. The clicking is coming from the vicinity of the flyback
: transformer.
: I've opened up the back and made a cursory check, seeing no burned or melted
: parts. What further steps can I take to isolate the problem? Would it
: likely be as simple as replacing the FBT?
: Thanks
