Mitsubishi VS-5043 no power.
David Farber
This Mitsubishi VS-5043 doesn't power on. At first, I could hear the power
relay click but nothing else powered up. I took the chassis into the shop,
tested the capacitors, touched up many of the intermittent connections,
plugged it in, and it powered up (bypassing the power relay). I reinstalled
the chassis and it worked well, for about a day. The customer called me and
said it turned off while it was in use. I am told now that there is no relay
click when powered up. Does anyone have a scan of the standby/power up
circuits so I can trace what's happening here?
Thanks for your reply.
David Farber
I removed the chassis again and found the main fuse blown with the STRM6811
shorted. Replacing both seems to have solved the problem, for now.
