MLTD3222 Memorex lcd Tv
Michaels3e
Dec 14, 2014
7
Hi Guys, I have this LCD that when you turn it on of course the picture comes up and then turns off MLTD3222 now it was always the Two caps that go bad .. but this one has 105j 630v Metalized Film Capacitors i checked the diode with the heat sink .. everything seems fine has anyone run across this problem? it's driving me Nuts .. heres a Picture of it Thanks a lot guys .. Michael
The big cap in the middle looks like it's bulgy.
Michaels3e
Dec 14, 2014
7
If you look that is a stock Photo.. The main Capacitor as you see in the Picture is always like that , it has 380 volts across it .. that cap is fine! I cannot find anything on this TV .. in order to fix it .. I refuse to buy another power supply, reason being.. that's not fixing the TV That's just replacing things , I wanna fix it . I wanna know what's wrong with this power supply and then in the future someone else can take a look at this thread and change what's wrong .. not replacing the whole power supply .. and help is much appreciated .. So guys , any other idea's? this is a tough one lol .. Thanks Guys
Anon_LG
Jun 24, 2014
453
Provide some more pictures, take 4 pictures showing each quarter of the board, some of the components are a bit blurry. You sould listen to davenn, they are made moderators for a reason. It is likely the capacitor is faulty, see this video. Overloads in electrolytic capacitors cause internal pressure. Look very carefully at the capacitors before they explode.
Please provide some more stock photos to allow us to diagnose your unit.
Michaels3e
Dec 14, 2014
7
Hi Guys, This is the original board I am working on in the pictures .. I never seen this before , The main filter cap is fine if you see the Orange caps those are the ones that we always replaced but those are the electrolytic caps . not the ones in the photo.. I cant find not service manual on this power supply and i sen very little info onfo this set. has anyone seen this set and fixed it? like I said swapping out the board is not fixing it .. I would like to know what component has gone bad Thansk for the help guys .. Stay Safe
Anon_LG
Jun 24, 2014
453
I can not spot any (visibly) damaged/broken components in there. There is a chance one of the integrated circuits has stopped working (due to over power etc) This may make solving the problem very difficult. The only thing visibly I can spot is highlighted in the orange ring, there is a sign indicating the placement of an smd integrated circuit however there is not one present, was there ever one present there? Check all of the capacitors, there are over 50 on the bottom board, and it looks as if there are several underneath those metal parts on the top board.
Michaels3e
Dec 14, 2014
7
There was none present on what you have circled ,, the thing is when you turn the set on the Picture comes up and you can see it for a couple of seconds and then goes out .. making me wonder if it's the orange caps in the corner just like the electrolytic ones that go bad.. the DVD in this set also works.. it accepts the disk .. so this set still makes me wonder
14,487
Those type of caps are pretty reliable they are NOT electrolytic caps
what about the 5 or 6 electros under that heatsink ( lower centre) ? they would be very suspect
Michaels3e
Dec 14, 2014
7
Well you might be right on that .. I seen a couple of post on it ..like I said in earlier post .. I refuse to replace the power supply .. in my opinion that is not fixing it .. I wanna know what is really wrong with it .. I will try that .. Thanks
Michaels3e
Dec 14, 2014
7
Well I changed the caps on the bottom of the power supply under the cage.. still the same .. I new that would happen .. Lost on this one ..
14,487
That long connector on the lower left of the PSU board, the one with the blue, blacks, brown, yellow and orange
looks like there are markings in the PCB as to what voltages may be present on what pins
can you clarify that please and if you have done any measurements there ?
