Martaine2005
- May 12, 2015
- 5,318
- Joined
- May 12, 2015
- Messages
- 5,318
If it gets too complicated with Edd, use my diagram for batteries > switch > resistor > LEDs.ok thanks for the help!
Yes, is the answer to your previous question of mine.
Martin
ok thanks again! )If it gets too complicated with Edd, use my diagram for batteries > switch > resistor > LEDs.
Martin
you said i can use a higher value for less illumination and a little lower for more illumination. would 27 ohm & 33 ohm be ok for that? wont harm the leds?Yes, Edd is very thorough.
First tell me the things you don’t understand.
But in the meantime, a 30 Ohm resistor will supply approximately 10mA to the LEDs from your 3xAA (4.5V) batteries. Assuming 2.1 Vf .
You can of course use a higher value for less illumination and a little lower for more illumination.
Martin
also, can I do it without the DC meter?wait so by your method will i be using the motion sensor's on off switch to power the lamp?
Here is your photo of the proximity switch.
I now see that its only a DPST switch vice 3PST but that will supply the needed switch, if you normally have the
unit in its turned off position.
I'm sort of expecting the two orange wires having one of those leads already connected to the +4.5 VDC battery source.
To confirm . . . . take DC metering . . . . set to the > 5VDC range, if not autoranging.
Meter negative goes to battery negative and with the prox pwr switch slid over to the off position check both of the orange wires to see if 4.5 is present, if so then all you need is a jumper wire from that wires switch terminal to the designated one on the new portion of that switch to now be used. Then only 1 wire needs to be run to the area of the Y1 and its RED dot foil area, with a 1K resistor in series at the end of the wire..
When the prox switch is in its off position the constant on LED drive is supplied to the Y1 switching transistor by your newly utilized other portion of that slide switch.
That's it . . .EASY PEASY.
HERE's your PHOTOGRAPH . . . . .
73's de Edd . . . . .
The severity of an itch always seems to be inversely proportional to your reaching capability.
Yes, absolutely fine.you said i can use a higher value for less illumination and a little lower for more illumination. would 27 ohm & 33 ohm be ok for that? wont harm the leds?
thanks )Yes, absolutely fine.
Martin
i can buy a new switch, but can you summarize concisely what i need to do please? because im confused.Sir
[B]cards1[/B]
Looks like for the total turning off the LED's that it would be best that you just installed a dedicated new SPST switch in series with that 1 K resistor.
Doing that, instead of using the vacant one on the vacant half of the motion sensor, since that use would be dependent upon
switching the sensor switch to its ON position, in order to disable the LED's constant on feature.
Then the miniscule power of that sensor in standby mode and quiescent COB should be the the only battery drain .
I can't see the use of the WHITE wired power button and its remoted wiring because PROBABLY that is being a momentary contact action push button that ACTUALLY will initiate a timed power on function within the COB, or else the COB then is driving one of the myriad of discrete transistors located just below it, for accomplishing that power switching.
Its not a conventional on or off switch, but a temporary, only on, with its pressed action.
BUT apparently you have no metering capability to confirm. Or a mechanic with no tools.
Now . . .GIT 'ER DONE !
And also answer the " to tweet or not to tweet " conundrum. . . . . . as, we is dying to know !
The easiest way to make a fire with two sticks . . . . is to FIRST make sure that ONE of them is a match.
" to tweet or not to tweet " conundrum? what is this lolSir
[B]cards1[/B]
strange, i didnt get a notification for your reply." to tweet or not to tweet " conundrum? what is this lol
It relates to your unplugging the MAIN mid and low frequency range standard speaker and then , with it thereby producing no sound. Cycle the unit thru a demonstration to see if high frequency audio or sound effects are produced by the small piezo speaker mounted just to the side of the main speaker . . . . . . understand now ?
But now Saint Edd has mentioned whether it’s a momentary switch. If it is, you also need a simple on/off switch of whatever takes your fancy.
I HIGHLY suspicion that the connecting wire remoted "on-off-power switch ", is going to be a push button type. . . . . . .of momentary on contact . . .when its being pushed . . . . . that initiates a timed turn on cycle, then cuts power off off, by the electronics within the COB chips circuitry.
Therefore, you could not use it for the powering on of your " special LED feature ".
PROCEDURE . . . .for the umteenth time . . . . .
A short lead 1K resistor gets one of its leads solder tacked into the RED dot foil area.
Its other free end is also short leaded and its sticking up, and that lead end get solder tacked onto a fine gauge hook up wire of "adequate" length to reach to the point that you have chosen to mount a dedicated on-off switch . That end of wire connects to one of the switches contacts. the other switch contact has another hook up wire connected to it and is routed to the B or C connection (same-same) on the top left photograph, to solder to that point.
also did you see the solution of the other guy? he said just to get a 30 ohm resistor & connect it all, with the original on off switch ***, do you think it will work?
FERGIDDABOUTIT . . . . . . . . . .because
***with the original on off switch
*** I HIGHLY suspicion that the connecting wire remoted "on-off-power switch ", is going to be a push button type. . . . . . .of momentary on contact . . .when its being pushed
Life is short, make fun of it.
can you give me the OK so I can order the stuff please, it will probably take close to a month to arrive )" to tweet or not to tweet " conundrum? what is this lol
ok I will order the things, I will get a 26 awg wire in case ill need it, will arrive in about a monthOMG, are we still on this?.
If your motion sensor switch is on/off, use that. Batteries >switch > resistor >LEDs.
Martin
ok thanks )Use any wire!. Speaker wire, telephone cable, alarm cable,broken USB cable etc. We are talking milliAmps, so don’t be concerned.
Martin
I can upset the rhythm of your heartbeat (skip a beat) with 40 milliamps.We are talking milliAmps, so don’t be concerned.
Yeah!I can upset the rhythm of your heartbeat (skip a beat) with 40 milliamps.
I like the way you put that.Yeah!
But he’ll be illuminating an LED, not sucking the wire!
