Mono amp feeding both stereo and mono headset without shorting out
WadoAdi
Nov 30, 2017
5
I have a what I thought would be a common issue and easy to find the answer on google but i can't !
here is my issue I have a small self-build headset tester which has a mono output which connects to a panel mount stereo jack socket, I wired the ring to ground and the tip and second ring to the output, this works well when the headset has a stereo plug. However some have a mono plug which results in the second ring shorting to the ground and killing the output.
I need both channels fed for the stereo headsets but need it to work on the mono ones too!
How could I solution this, could I link the left and right channels with a small capacitor or would that not work?
thanks
dave9
Mar 5, 2017
1,191
Seems most straightforward to just add a 2nd, mono jack in parallel.
WadoAdi
Nov 30, 2017
5
thanks and yes that would work as would adding a mono and stereo switch, however I really would like to use a single jack with a minimal of extra components and nothing further in the panel...
if I was to feed each channel via a 5K or 10k resistor?
Alec_t
Jul 7, 2015
3,817
I assume each 'channel' is intended to drive a respective earphone directly. If so, such a high value would severely attenuate the signal, since the 5k/10k would form a voltage divider with the earphone impedance (typically about 32Ω). I'd try 33Ω in each channel.
WadoAdi
Nov 30, 2017
5
@Alec_t thanks I will give that a try the headsets i'm using it with have an impedance of 300Ω and i thing i have some 280Ω resistors in bits box so will try them...
