More current to stepper motor
rj23
Jul 20, 2020
7
Hi all,
Bit of an odd one.
I have an aftermarket car ecu that has a 4 wire stepper motor attached to it.
Unfortunately, the ecu is current limiting to 1 amp.
The motor needs 1.85 amps (6.5 ohm motor, 12volts).
It therefore needs a bigger current supply (no position feedback needed).
Is anything available (make or otherwise) where the 4 inputs can be connected, and the higher current can be output?
thanks
Rod
Block diagrams do not help much.
If you can gain access to the step direction signals ( which I doubt) then you could use just about any driver.
Why you need to drive at a higher current is a mystery though.
rj23
Jul 20, 2020
7
The motor and the ECU are from different automotive applications. The rated supply of the ecu is insufficient to drive the motor in the other assembly.
Alec_t
Jul 7, 2015
3,820
You could use the ecu to control power MOSFETs to switch the stepper motor. The devil will be in the details.
bertus
3,868
@01sporty , The L298 is not going to work.
It can deliver 2 A per channel, but total device current is 4 A.
Bertus
  • L298.pdf
Minder
Apr 24, 2015
3,561
You also require some means of ensuring the winding current is a constant 1.85amps at all speeds.
M..
