- Joined
- Jun 21, 2012
- Messages
- 4,986
You didn't change the schematic to reflect the change in resistance value.The 1M resistor was replaced with a 10k resistor (brown-black-black-red - I write this to check myself, Adam not you - I am befuddled by a simple analog voltage divider right now!)
The LDR is in place and the pot is a 104 100k with center tap between LDR and 100k resistor. 100k resistor going to Vcc. Pot shows smooth transition of resistance across spectrum. In circuit, voltage ranges from .124V-.68v while LDR is illuminated. When dark it rises to 2.1 (continues to climb extremely slowly).
Can I assume this thing now works? The 2.1 volts should mean both transistors are on and the LEDs are illuminated when the LDR is dark. Is that correct?
