mosfet gate threshold voltage
http://www.powerdesigners.com/InfoWeb/design_center/articles/MOSFETs/mosfets.shtm
says:
4.5 Gate Threshold Voltage, VT , {VTH , VGS(th) }
VT is the minimum gate voltage at which the transistor will turn
ON.
Does this mean, 100% full ON? Or that the gate is Starting to turn On
(1% ON, for example)?
Do mosfets prefer to be fully on or fully off, or can they be run at
some point in the middle, continuously?
If I wanted a MOSFET to run at, say, 50% of full ON, would a MOSFET
cheerfully comply, or would it blow up?
Michael
Eeyore
says:
ON.
Threshold means starting to turn on..
Whichever you like subject to chip power dissipation and die temperature limitations.
Google for Motorola's AN1040 which goes into some detail about heatsinking.
Define 50% full on !
would a MOSFET cheerfully comply, or would it blow up?
It all depends. Cheerfully either.
As ever the devil is in the detail which you will have to learn I'm afraid.
Graham
Phil Allison
says:
ON.
** Go look up the word " threshold " in a dictionary - fool.
** Why do you keep posting questions you already know the answer to ?
Troll.
** For you - it would rather blow up than be mauled by an idiot.
...... Phil
http://www.powerdesigners.com/InfoWeb/design_center/articles/MOSFETs/...
says:
ON.
Starting to turn on, the datesheet will say what current, usually
something
like a few hundred uA
as long as you can get rid of the heat generated it doesn't matter
Michael
what do you mean by 50% on?
as long as you stay within the limits of the datasheet things should
be ok
-Lasse
something
Thanks - you've been most helpful
Thanks!
1/2 ID_max
be ok
-Lasse
Thank you very much for the helpful replies.
Michael
