MOSFET pull down in linear region
matt111111
Nov 26, 2014
4
I have a current sense IC powered directly from a battery. I want the current sense IC to be in the shutdown state when the 3.3V power supply is disabled.
I have added a dual N channel MOSFET circuit (see attachments) to achieve a pull down on the shut down pin (active low and internally pulled high) when the
3.3V supply is not present. The circuit seems to work in LTspice but I am concerned about one of the MOSFETS operating in the linear region. (VDS < VGS - VT)
Is it safe to operate the MOSFET in this configuration or is there anything I'm missing that is considered bad design?
Alec_t
Jul 7, 2015
3,820
Vgs = 30V would kill most fets!
Unless the 3.3V drops extremely slowly the linear state would be brief. With such high resistor values there will be only miniscule power dissipated in either fet.
