MOSFET question: Drive voltage vs. Vgs(th)
Can anyone tell me the difference between the drive voltage and the
gate-to-source threshold voltage (Vgs,th) of a MOSFET, if any?
I was under the impression that these refer to the same voltage - the
voltage that is needed to turn the MOSFET 'on'.
However, if you look at the following datasheet for a Fairchild
MOSFET...
http://www.fairchildsemi.com/ds/FD/FDG311N.pdf
you'll see that the title says "2.5V Specified", which I understand
refers to the drive voltage. However, under the "On Characteristics,"
you'll see Vgs(th) min. = 0.4V and Vgs(th) max. = 1.5V. Why isn't
Vgs(th) max. = 2.5V, as the title suggests? Is there a difference
between Vgs(th) and the "specified voltage"?
Thanks!
