mosfet RF amplifier with resistance
Matteo
hi all!
I would like to project an amplifier with gain>20 and bandwidth of 1Ghz
I had to replace the ideal current generator over the drain with a
resistence and I tried to satisfied the specifications (gain and
bandwidth) but I found very strange values of current and voltage!
maybe these specification can not be satisfied with this circuit design
but..
can you help me to understand where I made the mistake?
here is my work:
http://www.thebags.it/listing/ampli/mosfet_resistence.PDF
thank you!
(sorry for my english)
Jan Panteltje
hi all!
You must separate the AC characteristics from the DC settings.
YOur idea about the impedances may be correct for RC (not checked),
but at the same time you could use a different DC system by using decoupling:
Vb
| R1
[ ] Rd for DC
| C3
|-- [ ]R2 === C1 < Z
| R3 | C2 | |
Z sees R1 R2 and C1 parallel for high frequencies.
But you are now free to select a value for R1 to match the Id max of
the MOSFET, select a usable working point.
C2 decouples for AC, and R3 sets Id.
R1 could be a choke.
C3 causes a low frequency cutoff.
If you wanted true DC coupling, then probably your only option would be to go
differential.
The other issue is signal level.
Very small AC signals in a low impedance are easier to realize.
If you wanted a voltage gain of 20 in say 5 ohm, S (ma/V) of the MOSFET
need be very high.
Even at 1A /V and 5 Ohm Zd the gain would only be 5!!!
Winfield will be able to tell you about FETS with low capacitance and high gain,
but must it be a FET? At these low impedances know that transistors have
a much higher 'voltage' gain......
So multistage differential transistor amp...
Somebody is gone shoot at this......
Matteo
Jan Panteltje ha scritto:
hi all!
Vb
| R1
[ ] Rd for DC
| C3
|-- [ ]R2 === C1 < Z
| R3 | C2 | |
differential.
need be very high.
Thank you Jan!
I'm not very skilled in FET amplifiers
I missed to write that my target is to analise some design solution and
to understand why they are not so good in order to understand why the
differential amplifier is the best one for my purpouse.
I know that your circuit is better than mine about decoupling but I've
to use mine :p
for example, I found that:
if I choose Rd = 625 ohm => Id = 2.6mA
in order to have Av > 20 => Vov < 0.165 V => W = 412micron
but Bw = 0.5Ghz instead of 1Ghz
if I choose Rd = 500 ohm => Id = 3.3mA
in order to have Av > 20 => Vov < 0.165 V => W = 523micron
but Bw = 0.53Ghz instead of 1Ghz
so I cannot reach my specifications!
Things that I don't understand very well:
- the replacement of the ideal current generator with a resistance makes
the performances worse ..why?
- I supposed to work with R << r0. in the end I found that this
assumtion was true, why?
finally.. I haven't any book or doc about RF amplifiers, can you all
suggert me something?
Thank you very much! If you travel to Italy I'll cook spaghetti for you
all ;)
Jan Panteltje
Thank you Jan!
to use mine :p
Exactly.
We say: The MOSFET output is a current source.
Ideal current sources have infinite high impedance.
An infinite high impedance would give an infinite gain S x 00.....
So if you put a resistor parallel to such a current source, you get the resistor value.
Now the voltage gain is S . Rd, and this is a lower value.
Neither do I anymore....
There is plenty on the web.
But some remark, if you just want a RF amplifier at 1GHz, so not a _wide_band_ amplifier,
then you could use a parallel tuned circuit in the drain, and in resonance that will
have very impedance... and lots of real volatge gain (but a limited bandwidth).
Vb
|C4 | | )
=== | R1 |C1 )L1
| [ ] Rd for DC === )
/// | C3 | )
|---------------------------------- out
| R3 | C2
C4 is for RF decoupling.
Now The frequency is set by C1 L1, C1 inaprallel wit hthe MOSFET output capacitance etc.
R1 sets the Q and with tha tthe bandwidth.
It is safe to assume the drain impedance is about R1, so gain is S . R1
R3 set Id for DC.
Of cource you can add a second winding to L1, so make a transformer, to create any output
impedance you want (impedance transformation is the square of the turns ratio.
The transformed output load will appear parallel to R1 for AC.
This is normally how _tuned_ RF amps are done, not with RC only.
At 1GHz L1 could be a piece of stripline.
all ;)
Good, I will remember that :)
I did soome googling for 'transistor wide band amplifier diagram':
In case you wanted a wide band _RF_ amplifier, here is a nice link:
http://delivery.acm.org/10.1145/123...&coll=GUIDE&dl=&CFID=15151515&CFTOKEN=6184618
A DC coupled differential 10GHz (note the inductors):
http://www.uni-stuttgart.de/int/institut/mitarbeiter/MA_Publikationen/tao/2003_EL_diffTIA.pdf
Just google a bit :)
W
Wimpie
On a sunny day (Sat, 21 Apr 2007 11:14:15 +0200) it happened Matteo
Vb
| R1
[ ] Rd for DC
| C3
|-- [ ]R2 === C1 < Z
| R3 | C2 | |
differential.
need be very high.
Thank you Jan!
to use mine :p
all ;)
Hello Matteo,
For me a voltage gain of 20 up to 1 GHz with a single device seems
very high. Did you check the specs of your active devices?
I agree with Jan that you need a device with very high gm to realize a
voltage gain of 20. The High gm, may result in parasitic capacitance
in a range that even with Rd = infinite, you cannot reach a voltage
gain of 20.
I looked to your calculations. Your high voltage gain requirement
will result in reasonable gate current (via Cgd). Are you sure that
you can neglect the device internal gate resistance?
Your last steps, where you go to currents and resistor values, I
cannot follow.
If your amplifier has to work from DC (with voltage gain of 20 from DC
to 1 GHz), the balanced option is a good one. However, you cannot
separate the AC design from de DC design. You also may add some
inductance in series with the drain resistor(s) to improve the
response at 1 GHz.
Best regards,
Wim
PA3DJS
The Phantom
hi all!
but..
here is my work:
thank you!
Your schematic shows a Cout of 250 pF plus the mosfet output capacitance.
The impedance of 250 pF at 1 GHz is only about .6 ohms. To get a gain of
20 would require a gm of about 30 at 1 GHz. This doesn't seem reasonable.
The 250 pF load will make it very difficult to get your required gain
without some kind of impedance transformation.
John Larkin
hi all!
but..
here is my work:
thank you!
I think that 20 GHz gain-bandwidth product is difficult, maybe
impossible for a simple 1-stage mosfet amplifier like this. You just
won't find a fet technology that will give you the required Gm without
a huge amount of capacitance, at least in silicon. Every semiconductor
technology has its limits.
Adding some inductances ("peaking") in various places can roughly
double GBW, but that's not an option if this is an all-IC design.
A compound-semiconductor phemt might be able to pull this off. They
have phenomenal transconductance and tiny capacitances. 20 GHz gbw is
easy in a single-stage bipolar MMIC, in InGaAs or SiGe.
John
jure
John
Matteo,
as many others mentioned , it seems that the requirements
( GBW = 20 GHz , Cload = 250 pF) are too hard for a single transistor.
you may look at something like a cascode plus a follower-
buffer, or something like a Cherry-Hopper amplifier.
Jure Z.
Mike Monett
Hi Jure,
I'm having trouble finding information on the Cherry-Hopper circuit
configuration on the web. Some links require subscriptions, so they are of
little value.
There is a schematic in Figure 2 of
http://www.uni-
pdf (135kb)
(sorry for the wrap)
If you have time to look at it, is it the feedback from the MN3 source to
the MN2 gate?
The rest of the circuit seems very conventional. But its not clear why that
arrangement would be much more effective than other feedback
configurations. There's a bit of explanation in the text - do you know of
any other links that might explain it in more detail?
Regards,
Mike Monett
Mike Monett
Mike Monett said:
Hi Jure,
are of little value.
http://www.uni-
TIA. pdf (135kb)
to the MN2 gate?
that arrangement would be much more effective than other feedback
of any other links that might explain it in more detail?
Regards,
Mike Monett
Never mind. I found it.
Feedback to the base instead of the emitter. Cherry, Hopper, 1963 paper.
And here I thought it was some new exotic configuration discovered by a
computer running genetic software:)
Regards,
Mike Monett
jure
Regards,
Mike Monett
Hi Matteo and Mike ,
The trick here is to load a common source MOSFET with a TIA
( basically the two following devices ), providing a very low load
impedance for the CS input device.
In a cascode, the load of the first common source device is a Common
Gate device , with potentially Higher input Z.
Here are some nice references (beyond the original Cherry-et-al paper
that you have already found ):
http://www.trlabs.ca/trlabs/research/library/?new_url=paper/cal-C0241.html
http://www.trlabs.ca/trlabs/research/library/?new_url=paper/cal-C0290.html
there are many more papers available on the net, try google with
Cherry, VCSEL , transimpedance, etc.
the old papers mention Hopper, newer ones refer to Hooper
Thanks , Jure Z.
Mike Monett
tml
tml
Thanks , Jure Z.
Thanks for the help and nice links. Downloading them now.
I saw the reference to Hooper but thought it was a spelling mistake, since
your post spelled it Hopper:
Negative feedback to the base is also useful in high gain amplifiers
running on low voltage. One example is a simple 3 stage amplifier. The
collector of one transistor is connected directly to the base of the next,
and a simple pullup to VCC supplies current. The last stage supplies
negative feedback through a large resistor to the base of the first stage.
A series resistor and coupling capacitor at the input set the AC gain. The
DC feedback is much higher due to the blocking capacitor so the circuit is
quite stable with changes in beta, temperature and supply voltage.
These amplifiers can easily have bandwidths of a hundred MHz or so.
Regards,
Mike Monett
jure
http://www.trlabs.ca/trlabs/research/library/?new_url=paper/cal-C0241...
http://www.trlabs.ca/trlabs/research/library/?new_url=paper/cal-C0290...
Thanks , Jure Z.
Here is the C-H simplified AC circuit with NMOS
|-------VWV-----------|----------------|
|-- >-------VWV----|
| Zm |
|--------|_____________________________________|
IN ------| |
Note: BTW, Jan Panteltje directly pointed to the same C-H concept
earlier in this thread, referring to the Tao paper.
Thanks, Jure Z.
Mike Monett
|-- >-------VWV----|
| Zm |
IN ------| |
Thanks, Jure Z.
The diagram seems a bit garbled:)
I checked the source - it is the same.
Regards,
Mike Monett
jure
Regards,
Mike Monett
Sorry Mike ,
Google Groups ate my whitespace...
I drew the three fets one after the other emphasizing the location of
the feedback resistor Zm, from the Source of the last to the junction
of the first Drain and the second Gate.
Thanks, Jure Z.
Mike Monett
Matteo
hi all!
Vb
| R1
[ ] Rd for DC
| C3
|-- [ ]R2 === C1 < Z
| R3 | C2 | |
differential.
need be very high.
Thank you Jan!
to use mine :p
all ;)
Hello Matteo,
gain of 20.
cannot follow.
response at 1 GHz.
Best regards,
Wim
PA3DJS
Thank you all!
I tried to come to a conclusion about the Rd limits
my gain is Av = gm . Rd = Vdd / Veff
in order to increase the gain
if I decrease Veff I'll increase gm but I'll have to use a bigger W FET;
moreover if I take Veff < 200mV my equations will not be true any more!
if I increase Rd I'll not be able to have Vds = Vdd/2
therefore I'd like to have a infinite Rd <=> an ideal current generator
now I'll try to solve this problem using a cascode configuration
hope it's allright :-?
John Larkin
Hi Jure,
little value.
http://www.uni-
pdf (135kb)
the MN2 gate?
Regards,
Mike Monett
Negative feedback doesn't increase gain-bandwidth product.
John
jure
John
completely agree !
Jure Z
Mike Monett
completely agree !
Well, my question no longer applies since I found the feedback arrangement
is very old, 1963, and well-known, even though it is often misspelled:)
You can apply feedback to the base of the input stage, which lowers the
input impedance and requires a known and fixed source impedance, or you can
apply it to the emitter, which raises the input impedance and requires a
resistor in the emtter. Plus a lot of other details.
But I don't understand the point of your comment. It is obvious, but what
does it have to do with the feedback configuration?
Regards,
Mike Monett
