Mosfets and second(ary) breakdown
A note to those who already know this... I've just learned this and I thought it was interesting enough to post -- I'm not claiming to have discovered it!
A common statement is that "mosfets are not subject to secondary breakdown". It's one I've made multiple times and is one that appears in a lot of authoritive material.
However, after considering second breakdown in diodes, I wondered if you could indeed have second breakdown in mosfets (since, at the very least, they have a body diode).
Second breakdown in a reverse biased diode is an effect which occurs after avalanche breakdown. Essentially, after some time, the device breaks down again to a lower voltage. The cause is essentially thermal, with heating causing a defect which partially or completely shorts the device -- read the document linked to above for a more complete discussion of the discovery and explanation of the cause.
Second breakdown can occur in the forward or reverse direction. In some respects, I would consider the shorting of a diode due to massively large forward current to be caused by secondary breakdown (does anyone disagree?).
The cause, as I understand it, comes down to the fact that at higher temperatures the breakdown voltage is lowered. Because the current through the junction is heavily influenced by the breakdown voltage, reducing it slightly leads to a significantly higher current. This tends to cause the power dissipation , rather than being spread out over the entire junction, to be more and more concentrated. If not controlled, the rise in temperature increases to the point at which physical damage occurs. BJT's having junctions, are subject to this, but since mosfets do not...
If mosfets are used in linear applications and the Vgs is very slightly higher than Vgs(th), the channel is very close to being pinched off at the source end. While the resistance of the bulk material has a positive temperature coefficient, Vgs(th) has a negative temperature coefficient. This means that a slight unevenness in current flowing through the narrow region can cause localised heating which will reduce the Vgs(th) at this point. This condition is potentially unstable, leading to thermal runaway. The result is that the current flows through a narrower and narrower channel until the ohmic heating results in damage to the semiconductor. Here is one application note which covers the region of thermal instability in the mosfet SOA.
14,308
Since modern power MOSFETs internally consist of thousands of tiny MOSFETs in parallel, local overheating is an issue for them, too. May I point to this app note on using MOSFETs in linear applications? It is in essence similar to the one you linked. Just a second opinion.
The references I've found say that it is *more* of an issue with modern mosfets.
CDRIVE
May 8, 2012
4,960
Yet another revelation that I'm reading for the first time. I'm not too proud to admit it....Sucks though! :(
Chris
Anyone who's interested probably scratched their head at this. Zener voltage decreases with temperature, but avalanche voltage has a positive temperature coefficient.
The trick is that whilst avalanche voltage does have a positive tempco, at elevated temperatures this trend is reversed. Hmm this is true for Germanium (page 20). For silicon, some of the ionization coefficients have a negative tempco (see here, page 18). I think they result in the same behaviour???
Also interesting (and seemingly having some similar thermal interactions) are SEB (single event burnout) caused by a heavy ion smashing into the junction.
