Most efficient 1v boost circuit.
cjdelphi
Oct 26, 2011
1,166
I've been simulating a few 1v boost circuits out of boredom, looking for the most energy efficient circuit(s)
And all of them, this one (attached) image seems to be the winner for a realitively low number of components, i built this circuit last night and 12 hours later it's still just as bright!
cjdelphi
Oct 26, 2011
1,166
The joule thief is surprisingly not that good unlesd you have a high inductance going, the one in the photo has already doubled the life of the regular joule thief!
cjdelphi
Oct 26, 2011
1,166
The ebay one is actually the same circuit design as the attached image
Results in, joule thief lasted for 2 days, the first circuit i posted lasted 4 1/2 days (all brand new 2.4amp energizer aa nimh)
But the QX5252 is the winner lasting for 5 days, to make it fair i used the same 330uh inductors..
Next circuit to test with is a flip flop circuit (transistors) and an inductor...
But the qx5252 is great for low voltage lighting solutions
You are comparing running time, but to compare efficiency you need to compare the output as well. The Joule thief and your original circuit are flashing the LED with unknown current and duty cycle. The boost converter would be running the LED at a contant current. If you really want to compare the efficiency, you need to measure the light output, or at least integrate the current through the LED over time as an approximation.
cjdelphi
Oct 26, 2011
1,166
They all produced equal brightness, i doubt i was out much more than a few ma
