Most novel LED flasher ?
Andre
Hi group
Anyone got below 4 parts + LED (rules :- no chips with more than 4
pins, no PUTs or UJT's, no inductors, no hand picled parts ) ?
So far I have got down to 6 parts + LED, using a regulator IC .
-Andre
W
Wouter van Ooijen
I would cheat: take an 8-pin PIC and remove the 5 unneeded pins (after
programming, because that requires 5 pins).
Wouter van Ooijen
http://www.voti.nl
PICmicro chips, programmers, consulting
Tony
I thought the challenge of this, since the demise of the LM3909, was to get it
to run off a single cell?
Tony
V
Vladimir Vassilevsky
Logic NOT gate in SOT-23-4 package + resistor + capacitor = 3 parts.
Two transistors + resistor + capacitor = 4 parts.
Self flashing LED = no parts
Vladimir Vassilevsky, Ph.D.
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
K
Ken Smith
Hi group
1 resistor
1 Thermostat taped to resisitor
John Larkin
Hi group
-Andre
1 mosfet
1 resistor
(Guess how?)
John
A E
Andre said:
Hi group
-Andre
Is a battery included in the 'parts'? And how many times does it need to flash?
Whatever happened to UJTs? sigh....
N
N. Thornton
Hi group
-Andre
Hi
If we could use hand pickled parts, just what would we do with them?
Think... light emiting diode... will a pickle behave as a diode? if
so, the hand pickled onion can be our light emitting diode, with the
help of about 240v. Aha, as it burns up it may well flicker and flash
to some extent too.
I like the idea of cutting some pins off that 8 pin IC better - bit
more practical :)
BTW would the fork prongs be classed as pins? Mind you, if its not a
chip, it could have as many pins as you like according to your above
spec. So you cant eat the pickle with chips.
Regards, NT
CWatters
Someone wrote..
Use a LDO regulator with the wrong output capacitors to make it unstable -
can't be sure it will oscilate at the right freq though.
Rob Judd
You win! You win!
Rob
F
Fred Bartoli
Andre said:
Hi group
-Andre
What about a fluorescent lamp starter (and maybe a shunt R)?
Fred.
John Larkin
Hi group
-Andre
OK, here's an easy one:
1 SOT-23 TinyLogic gate
1 resistor
1 capacitor
John
W
Watson A.Name - 'Watt Sun'
PUTs are still around.
The simplest is to use 3 pin flasher chip (mostly sold in 4-bonding
pad die form for inclusion in LEDs, but TO-92 package is available).
Best regards,
Spehro Pefhany
Just 1 part, a buzzer or relay connected as a buzzer. Maybe a current
limiting resistor. Nothing was said about flash rate. If that is too
fast, add weight to the armature to slow down the flash rate.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
K
Kevin McMurtrie
Hi group
-Andre
Apply tiny current through a blue LED backwards. Now run it under
normal conditions. It will flicker and flash as its damaged crystal
burns away.
W
1 resistor
1 capacitor
John
No I limit resistor in series with the LED? So what's the supply
voltage?
John Larkin
voltage?
Whatever makes the LED look good. If the resistor is big enough, you
can leave out the cap!
John
N
N. Thornton
Hi
another one: resistor + capacitor + neon to make a neon flasher.
Supply V should be close to neon Vbreakdown. Now put LED in series
with the R so LED lights during C charging, but goes out as C nears
Vmax.
Of course you dont need the LED, you could in most cases leave that
out.
Regards, NT
I
Ian Stirling
burns away.
Apply a really tiny current through a standard LED.
It will emit photons more or less randomly.
Only need a resistor.
