[email protected]
- Jan 1, 1970
- 0
Hi, I had a loose power socket and superglued it and that lasted just
fine for a few months. Then it went out beyond
an ability to glue it again, but still have a occasional power
connection when moving it. I pulled out the motherboard and the solder
on the bottom side of the board where the socket connects, the solder
was burnt away and brittle.
I'm not much of a solderer, just have a cheap soldering iron with a
large tip. Is there a pretty much common method to repair this, I was
thinking of dropping a drop of solder where the solder failed instead
of finding somebody to repair it. Then putting the laptop back
together and see if it works and do a re-superglue of the offending
loose socket.
Thanks for any tips or suggestions. Tools needed, over my head in my
abilities?
It's a compaq presario 1692
loose socket.
abilities?
