Hi. What I have is a 3 phase 5hp GE motor 1170 rpm (pretty old). It has been set up with some electronics (I have no idea how this works) that convert the single phase into 3 phase. My father in law used to run it under no load and had an extension cord running off of it to run some 3ph equipment. Worked awesome. I have taken this motor and hooked it up directly to a Little Giant Power Hammer via a 4" canvas pulley. The power hammer specs call for a 2hp motor so this 5hp 3ph should have tonnes of torque. As soon as there is the slightest load it just hums and then stops. Even hand turning the belt doesn't help.
I have tried super minimal tension (can slide the belt on and off) and still no go. Is it likely that the motor just needs a tune up or am I most likely going to need to get a proper roto-phase convertor? Really hoping to get this motor working as I've just spent almost $300 on a making a 4" belt and pulley to match.
Thanks for your help!!
