MultiChannel Remote Robot
Moha
We wanna build a multi-channel communication system with either
Frequency Hopping or Spread Spectrum to eliminate the effect of
Jamming on the system. We want to have it for long range typically
10Km and could be expanded to longer distances if the prototype
works.
The system will be used with SWAT team for sending Live Video
streaming to the Command and control center. The Cameras that will be
used would be over a helmet like the ones which are used with the
Racing cars.
Could anyone suggest to me ideas on existing products or help me in
building one.
regards
Supercircuits.com sells law enforcement RF video parts if you have a
sworn officer contact them.
Even if your swat I see no reason for you to need secure video. The
odds of you being jammed, ever, are nil.
Steve
Moha
Steve
Thanks Steve
I have checked the website. The requirement is to have Wireless
camera with long range. If we wanna use 2.4 Ghz it would be exposed to
interference to preferable to use 900 Mhz or even 433 Mhz. That is why
we are looking for high data rate and DSS or FSS.
Mohammed.
JosephKK
works.
Racing cars.
building one.
regards
If you were competent enough to get the contract it is up to you to
perform on the contract. It is perfectly doable, if you know what you
are about. If you want help here for that, bring your current design
and we will critique it for you. If you do not have a base design to
write your proposal around, you do not belong in the market.
