multiple 555's ?
could I / how would I, use multiple 555's (or 556's) to trigger
4 optocouplers (moc3010) in sequence?
when I turn the circuit on, I want it to:
turn on the first opto for 5 seconds, turn it off,
wait 3 seconds,
turn on the second opto for 5 seconds, turn it off,
wait 3 seconds,
turn on the thrid opto for 5 seconds, turn it off,
wait 3 seconds,
turn on the fourth opto for 5 seconds, turn it off,
wait 3 seconds,
repeat continuously until I turn the switch off.
John Popelish
wait 3 seconds,
wait 3 seconds,
wait 3 seconds,
wait 3 seconds,
I think you can perform this with a 555C (CMOS version of the 555), a
CD4022 decoded divide by 8 counter (to produce the 8 timing states)
and a little circuitry to power the counter up in a given state and
feed the 4 short states back to the timer to speed it up. You will
also have to pay attention to the first time cycle which tends to be
long compared to later cycles. This is just my first reaction to your
problem, not completely thought out. The smaller and more consistent
approach would be to use a microprocessor.
John Fields
wait 3 seconds,
wait 3 seconds,
wait 3 seconds,
wait 3 seconds,
Anand Dhuru
You could accomplish this (and more, if required!) very easily with
just one 8 pin PIC device like the 12F629.
GPG
R2 should be abt 300K. If you use a 4022 instead of the shift register
it will not need the logic after the XOR
John Fields
W
Wayne
wait 3 seconds,
wait 3 seconds,
wait 3 seconds,
wait 3 seconds,
Microcontroller is an easy approach and gives flexibility to alter timing.
Below is a simple programme which would get you going. You could incorporate
the remaining unused pin (pin 3) into the programme and use as an on/off
switch - ie. detect high or low on input. Chip is a PICAXE 08. These chips
are used by students so they have to be easy. Chip will drive the opto's
directly via a 330 ohm res.
To make a programmer: Grab an old mouse, chop off the mouse and wire it via
a couple of resistors to a piece of vero board. Instructions on site.
All info at http://www.rev-ed.co.uk/picaxe/
'PICAXE 08 Microcontroller - 8 Legs (5 inputs/outputs referred to as pins)
'Leg 1 +5V
'Leg 2 reserved for programming
'Leg 3 Pin 4 input or output
'Leg 4 Pin 3 input only
'Leg 5 Pin 2 input or output
'Leg 6 Pin 1 input or output or analogue input
'Leg 7 Pin 0 output only (also used for programming)
'Leg 8 0V
start: low 0
low 1
low 2
low 4
main: high 0
wait 5
low 0
wait 3
high 1
wait 5
low 1
wait 3
high 2
wait 5
low 2
wait 3
high 4
wait 5
low 4
wait 3
goto main
Cheers, Wayne
manuka
Totally agree on PICAXE approach = versatile,REALLY EASY to use,lower
parts count & jelly bean CHEAP!(~US$2-3 each). Peter Anderson (=>
www.phanderson.com )handles US sales. Win editor is a free download (
www.picaxe.com) & programmer involves 2 resistors - a huge enthusiatic
support has evolved UK/Australia/NZ. The baby 08 is just one of 8 in
the Picaxe family in fact, with the bigger brothers (all still cheap)
featuring IR decoding,PC keyboard + DS18B20 reading etc & up to 600
lines of PBASIC code space. Google *picaxe* for more insights.
F
Fred Bloggs
wait 3 seconds,
wait 3 seconds,
wait 3 seconds,
wait 3 seconds,
A 555 circuit would look like so- as you can see, it is a project- there
is no start-up pulse elongation- switch should be OFF 10 seconds before
you re-start. Modular supply with outputs isolated from chassis assumed:
Please view in a fixed-width font such as Courier.
*bypass each '555 with 0.1u capacitor
10K
| +-----------+ 5V |
| |5V SUPPLY | | + |
| +-----------+ | | 10U |
| | OV |
| +-SW--+ | |
| 0V | o |--+ ON |
+------------------------|o/ | |
| | o |--+ OFF |
chassis | |
gnd | |
| 0.47U 470K |
| | +-----+ | e |
| .--+-------+---. | | \| 4.7M |
| | RST TRIG| | | |--/\/\-----+ |
| 5V---|V+ | | | c 2N4403 | |
| | LMC555 | | | | | |
| 0V-+-|GND DIS|----+ +-|---c | |
| | | | | | | \| 47K | |
| | | THRESH OUT| | | | |--/\/\-+ |
| | | | | | | e 2N4401 | |
| | | | | 0V | |
| | | | | 4.7M 3.3M |
| | | .--+-------+---. | | |0.47U | |
| | | | RST TRIG| | | === | |
| | 5V-+-|V+ | | | 0V | |
| | | LMC555 | | | | |
| | 0V---|GND DIS|-----------------+ |
| | | THRESH OUT| | | 1K 1K |
| | | | | | | c | |
| | | +---+ | | |/ | e
| | | | +----|2N4401 | |/
| | | | 4.7k | | |\ +-----| 2N4403
| +-----------+ +-/\/\-+ | e |\
| | | c
| | 0V |
| | 10K |
| | RST TRIG| | |
| | | ===0.1U |
| 5V---|V+ | | |
| * | LM555 | | 1K |
| 0V-+-|GND | +---/\/\----+
| | | THRESH OUT| 0V |
| | 1N4148 |
| | | 0.001U |
| | 10K | 10K | 4.7K |
| | | .--------------. MOCXXXX | |
| | | | RST TRIG| .-----. Rx | |
| 5V-|-+-|V+ | | .-----. | |
| * | | LM555 | +--------+-----+ | |
| |0V-|GND | c | | |
| | | | 2.2K |/ | | |
| | | THRESH OUT|---+--/\/\-|2N4401 | | |
| | | | e | | |
| | | | 0V | | |
| | | +------------+ 0.001U | | |
| | | 10K | 10K | 4.7K | | |
| | | | .---+----------. | MOCXXXX | |
| | | | | RST TRIG| | .-----. Rx | |
| 5V----|--+-|V+ | | | .-----. | |
| * | | | LM555 | | +--------+----+ | |
| | | 0V-|GND | | c | | |
| | | | | | 2.2K |/ | | |
| | | | THRESH OUT|--+---/\/\-|2N4401| | |
| | | | e | | |
| | | | 0.001U 0V | | |
| * | | | LM555 | | +--------+-----+ | |
| | | 0V-|GND | | c | | |
| | | | | | 2.2K |/ | | |
| | | | THRESH OUT|-+----/\/\-|2N4401 | | |
| | | | e | | |
| | | +------------+ 0V | | |
| | | | 0.001U | | |
| 5V-+-|V+ | | | .-----. |
| | LM555 | | +--------+---------+
| 0V-|GND | | c
| | | | 2.2K |/
| | e
0V
John Fields
10K
| +-----------+ 5V |
| |5V SUPPLY | | + |
| | OV |
| +-SW--+ | |
| 0V | o |--+ ON |
| | o |--+ OFF |
chassis | |
gnd | |
| 0.47U 470K |
| | +-----+ | e |
| | LMC555 | | | | | |
| | | | | | | \| 47K | |
| | | | | | | e 2N4401 | |
| | | | | 0V | |
| | | | | 4.7M 3.3M |
| | | LMC555 | | | | |
| | | | | | | c | |
| | | +---+ | | |/ | e
| | | | +----|2N4401 | |/
| | | c
| | 0V |
| | 10K |
| | RST TRIG| | |
| | | ===0.1U |
| 5V---|V+ | | |
| * | LM555 | | 1K |
| | | THRESH OUT| 0V |
| | 1N4148 |
| | | 0.001U |
| | 10K | 10K | 4.7K |
| |0V-|GND | c | | |
| | | | 2.2K |/ | | |
| | | | e | | |
| | | | 0V | | |
| | | 0V-|GND | | c | | |
| | | | | | 2.2K |/ | | |
| | | | e | | |
| | | | 0.001U 0V | | |
| | | 0V-|GND | | c | | |
| | | | | | 2.2K |/ | | |
| | | | e | | |
| | | | 0.001U | | |
| 0V-|GND | | c
| | | | 2.2K |/
| | e
0V
GPG
Terry Pinnell said:
By cropping wasted space and saving as a GIF instead of BMP, your
enormous 440 KB file became 6 KB.
Yes. I have just loaded a file converter. Previously using paint to convert to bmp
GPG
Schematic has a problem on start
I thought someone would critcise it.I await
