multisync CRT monitor horizontal sweep
Choreboy
I have an NEC multisweep monitor. A week ago the raster began to shrink
a few millimeters for a second or less. It can happen several times in
a matter of minutes. It can happen shortly after startup or when the
computer has been on all day.
It can run all day with no trouble. Putting the computer to sleep and
waking it, or changing screen resolutions, can cause the problem to
start or to stop.
Four years ago, I had similar symptoms with another multisync CRT
monitor of another brand. One day it failed suddenly.
Both monitors had relays that apparently cut current to the flyback
circuit each time I put the computer to sleep or changed resolutions.
Because I put my computer to sleep each time I leave my desk and I play
games that change the screen resolution, that relay may have opened and
closed 50,000 times in four years.
I'm afraid the relay points have started to burn and one of these days
they won't work at all. Otherwise, the monitor works fine and the
circuitry looks clean without signs of heating.
Rather than buy a new monitor, I'd like to try a new relay. Where can I
get one?
Michael Kennedy
Well it would help to have voltage and amp rating of the relay. The model
number of the monitor might also be good.
Choreboy
The monitor is an NEC MS75 (MultiSync 75), dated August 2001. I doubt
the electrical specs are on the relay. I was hoping the part number
would be on a parts list. Otherwise I can probably locate the suspect
relay by sound if I can run the monitor without the back and base.
