I am not able to understand why they have used R5 , because when I simulate the circuit taking out R5 , it still works the same , with little disturbances. What is the real need for using R5. Please helpR5 and R6 are two resistors in series between two voltage sources. If the two voltages are not equal, the voltage at the center node formed by the two resistors can be calculated using Ohm's Law.
The corner frequency is calculated using the equation for the corner frequency of a single-pole R-C circuit. For the R, use the Thevenin equivalent or R5 and R6, which is the calculated value of R5 and R6 in parallel.
ak
Hi, in the above circuit , to calculate Rc , what should I use as IC(Max) ? Since there's no load , what should Ic(max) be ?R5 is the bios resistor for q1 along with r6, c1, and the pulses from v2, they set the voltage on the base of q1 which raises the emitter of q1 to set the frequency of the multivibrator.
