Must convert LED strip to 12 volt
Skippi
Feb 26, 2017
Hello, I have an LED strip which currently uses a transformer from 240volt to manage the input voltage & current
I need to power it using a 12 volt deep cell battery (60amp) and a solar panel instead
Please could someone tell me what to use. I have no experience other than knowing how to solder and changing basic things like fuses and plugs. I think I understand why we need resistors and have found some websites that calculate the resistors needed, but the strip is already there and has no marking on it that I can read.
I assume I need to count the leds but is there any way I can measure their output so I can have more info? What I am really hoping for is someone to tell me all I need is one resistor and a fuse and a switch :)
the photo is taken from the 240volt transformer box
duke37
Jan 9, 2011
5,364
It looks as if the PSU is 12V DC and a 12V battery would replace this without any other modification.
Skippi
Feb 26, 2017
Thanks for replying. I thought i had to add resistors to stop the leds from overheating. Thats great. So a fuse and a switch is all i need? 5amp? And i have to make sure the wire is big enough yes?
