My inverter is not working and, please help I may not graduate because of this
TarfaEE
Apr 1, 2021
3
Hello all,
I'm building a three phase motor controller, I've designed the circuit on a PCB and I'm trying to test the inverter and it is not working.
I'm using an IR2104 to drive the mosfets, the LO is fine but the HO is a noisy dc signal for some reason. I'm driving it with a 64khz PWM signals from an Arduino due.
I made sure the low mosfets are on first (to charge the capacitor).
attached is the schematic and the PCB layout. Originally I used am IRS2186 but I changed it to IR2104 with the appropriate connections made.
  • [No Variations].PDF
Alec_t
Jul 7, 2015
3,821
I don't see a connection between the VS input of the IC and the top MOSFET's source. Without that the boost won't work.
TarfaEE
Apr 1, 2021
3
Vs is connected to the phases of the mosfet. It’s the mid point between the upper and lower mosfets
Alec_t
Jul 7, 2015
3,821
That's where it should be connected, but I don't see it in your schematic or board layout.
TarfaEE
Apr 1, 2021
3
It is connected the whole red via surrounding the top mosfet is conducting, I just checked using continuity test on a multimeter
