Attached are some pictures of the PCB for a noise generator I'm currently building.
I used the toner transfer process with magazine paper. For the silk screen I covered the toner with a thin conformal coating to stop it from being scratched off.
It isn't perfect but it's good enough for me - the traces all etched perfectly which is the most important thing.
Although I've experimented with printing a silk screen before, this is the first time I've done it for real. As you can see it isn't perfect. The toner all stuck perfectly, but some bits came off when I cleaned it so I filled in the gaps with a permanent marker which ran when I sprayed on the conformal coating. The alignment also isn't perfect and there's some slight bleeding which I think could be caused by the temperature setting being too high.
I've learnt a couple s few things from this. Next time I'm going to be more careful cleaning it, I'll a pencil to do touch ups and iron using a slightly lower temperature setting.
