They use a PA ( phone assistant ) system and and amplifier for all the basketball games. This appears to be two or more seperate systems. The board, the speaker, and the amplifier. Since there is a lot of wires under the bleachers taped, does anyone know how long it takes before the wires start to corrode? Yearly maintenance. Also if the speakers like Kenwood use the standard coaxial cables on all equipment. Will the distance in cabling affect the transmission of sound? Where can I buy extra cable in the local market? Hardly any electronic stores in the area. How much would you charge if they ask you to replace all the corroded and standard cables to newer cables?
