My solderstation failed
Staigen1
Oct 26, 2003
695
My Weller WECP-20 solderstation failed. Anyone got a sevice manual or at least a shematic for it?
//Staigen
SM2GXN
Hi Staigen!
I might have schematic on the WECP-20 at my work, use to repair them but never had any fault that needed schematic yet meaning that faults were not hard to solve.
I'm on vacation right now but I have to stop by at work on monday, forgot some books there. I'll check if we have any.
What is the problem with your WECP-20?
Björn
ante1
Jan 24, 2004
4,138
Hi Staigen,
I case Bjorn don't have any, I have two Weller schematics. I don’t know if there are any similarities what so ever but I hope they will give you some guidance. ;D ;D
Swedish teamwork! 8)
Weller_EC-2002.pdf
Weller_S80.pdf
  • Weller_EC-2002.pdf
  • Weller_S80.pdf
Staigen1
Oct 26, 2003
695
Thanks Björn(Bjorn) and Ante. The EC-2002 shematic seem so be similar to the WECP-20 (minus the display). Maybe you know by desciption whats wrong. This happens: when you switch it on the green lamp comes on and it start to heat, but in a minut or so the green lamp goes out and the tip is just only a little warm and start to cool down.
//Staigen
ante1
Jan 24, 2004
4,138
Hi Staigen,
I have very little to non experience with this type of station but my guess is the heat element has an open circuit once it gets a little hot! Try to measure the resistance in the element when it is hot (as hot as it gets) and then let it cool of while the meter is still attached. This might be a long shot, but I would start from there.
Staigen1
Oct 26, 2003
695
Ok Ante, i will check that, but will the green light go out if the element i at fault? I dont think so, only the element will cool down and the led still lit all the time, but im not shure.
//Staigen
Staigen1
Oct 26, 2003
695
Thanks tnk2k, thats what i needed, i belive. Also a shematic would be nice, hopefully Bjorn have one. Thank you all :)
//Staigen
ante1
Jan 24, 2004
4,138
Hi Staigen,
Have you measured the resistance between pin 3 and 4 on the 5-pin connector (iron side) hot and cold?
Staigen1
Oct 26, 2003
695
Hi Ante, i just measured the element cold, and its 12 ohms, but the temp sensor element seem to be a little high, 28 ohms. Do you know if it have a positive or negative temp coefficient?
//Staigen
ante1
Jan 24, 2004
4,138
Hi Staigen,
Did you notice any change between hot and cold during this measurement?
SM2GXN
Hi Staigen!
I'm sorry but we didn't have any schematics for WECP-20.
I got one my self and have never had any trouble with it.
Those we got at my job usually got bad elements or broken cable between the connector and soldering iron.
Up on what you describe I would suspect the element, I've replaced quite a few  ;D
Bjorn
Staigen1
Oct 26, 2003
695
Hi Ante and Bjorn and all you others :), sorry i dont have been online for a week, but my computer chrashed :(, i belive it was some kind of virus, i am now at a friends computer and write this. I havent had any possibillitys to check anything at my solderstation this week :(, and not my computer either :(. Im going to upgrade the computer this comming week :), it will take almost the whole week, i belive. See you then, on my own computer, hopefully :).
Staigen
ante1
Jan 24, 2004
4,138
Hi Staigen,
Sorry to hear about your computer, maybe you should install some virus protection while upgrading then! ;D ;D
Staigen1
Oct 26, 2003
695
Hi Ante, i had Grisoft AVG, but it did not react! I also had an old version of Norton antivirus, not updated in several years! Does anybody have a copy of "Lost and found" maybee?
//Staigen
