jstevenperry
- Nov 25, 2005
- 68
- Joined
- Nov 25, 2005
- Messages
- 68
In building another project I need to whip together some AND gate logic. Basically I want to produce high output if and only if my two inputs are high. Easy stuff, right? Everything seemed to be going well, but my output wasn't what I expected. In diagnosing the circuit (I stripped it down to the simplest circuit that reproduces the problem - see attached JPG), I noticed that there was something fundamentally weird going on. Here's the setup:
Circuit powered by 9V battery, running through a 7805CT +5VDC regulator (to power the 7408 gate). Nothing else interesting related to this problem. the IC is connected to two things: +5DVC and Ground. No other pins are connected to anything (take a look at the picture to see what I mean).
Here's the weird part: there is a roughly 1.65V potential (relative to ground) appearing at every A and B pin, and 3.6V at the Y pin (the 7408 is a quad gate IC, so there are 4 A's, 4Bs and 4Y's for the basic AND formula: AB=Y. I've included the spec sheet in case my explanation isn't clear.) So basically every input pin appears to be OUTPUTTING a voltage of 1.65V!!!
Of course, I would expect the input pins to be, well, input pins...not have a potential appearing at them. It took me quite a while to discover this mystery voltage, which appears at the input pins whether they are connected to anything or not (you can imagine what weird weird things it was doing to the rest of my circuit!).
Anybody ever seen this before? I'm baffled! I've also tried every other 7408 I have on hand (for a total of 10), same thing. I even tried a NAND to see if the mystery voltage appears at its input pins. And yes it does. So, is there some other circuitry I need? I figured I could just run two input voltages into the gate's inputs and get an answer. It's not that simple is it? Any help is appreciated! Thanks!!
7408-AND-49146.pdf
7408-AND-49146.pdf
