N Bit ALU
vead
Nov 27, 2011
473
how to make N bit ALU
ALU has two input word A, B
N bit ALU
An input
Bn input
F input
example
1 bit alu
0+1=1
2 bit ALU
01+10=11
4 bit ALU
0101+1010=1111
example -
1 bit ALU
1 bit input A
1 bit input B
1 bit output F
Code:
s         ALU performance
0        F= addition
1        F= A and B
same for 2 bit ALU
2 bit ALU
2 bit input A
2 bit input B
2 bit output F
Code:
S0  S1          F
0    0         F= addition
0    1         F= subtraction
1    0         F= A and B
1    1         F= A or B
for 4 Bit ALU
4 bit ALU
4 bit input A
4 bit input B
4 bit output F
Code:
S2  S1  S0              F
0     0    0            F= addition
0     0    1            F= subtraction
0     1    0            F= shift right
0     1    1            F=shift right
1     0    0            F= A and B
1     0    1            F=A or B
1     1    0            F= A not B
1     1    1            F= A and B
14,306
You need a funvtional unit where the function can be controlled by the S-inputs. Tis is described e.g.here.
Check your function codes: S= 100 and S=111 both are F=A and B. Is this what you want? Also you should clarif S=110. I do not understand what F=A not B means.because "not" is a unary operator, not a biary one (not works with one input only, it does not calculate an output from two inputs).
vead
Nov 27, 2011
473
I am not sure what function are you talking ?
lets see for 2 bit ALU
same for 2 bit ALU
2 bit ALU
2 bit input A
2 bit input B
2 bit output F
Code:
S0  S1          F
0    0         F= addition
0    1         F= subtraction
1    0         F= A and B
1    1         F= A or B
function F= A&b (A and B logic )
A B F
0 0 0
0 1 0
1 0 0
1 1 1
14,306
Did you read the ínformation I linked in post #2?
14,306
O.K. Now where' the question?
This is just one function (A & B). You want to make the function being controlled by the function code inputs (S0, S1, S2). How would you do that? (hint: it's in the linked text).
vead
Nov 27, 2011
473
for 4 Bit ALU
4 bit ALU
4 bit input A
4 bit input B
Code:
S2  S1  S0              F
0     0    0            F= A and B
0     0    1            F= A or B
0     1    0            F= A Nand B
0     1    1            F= A nor B
1     0    0            F= A Xor B
1     0    1            F=A X nor B
1     1    0            F= A addition B
1     1    1            F= A subtraction B
Code:
S2  S1  S0             A     B     F
0     0    0           0     0      0         AND
                       0     1      0
                       1     0      0
                       1     1      1
0     0    1           0     0      0        or
                       0     1      1
                       1     0      1
                       1     1      1
0     1    0            0     0      1          NAND
                        0     1      1
                        1     0      1
                        1     1      0
0     1    1            0     0      1        NOR
                        0    1     0
                        1    0      0
                        1     1      0
1     0    0            0     0      0          Xor
                         0    1     1
                          1    0      1
                          1     1      0
1     0    1            0     0      1          X nor
                          0    1     0
                          1    0      0
                          1     1      1
1     1    0           0     0      0          addition
                        0    1     1
                        1    0      1
                        1     1      0
1     1    1            0     0      0        subtraction
                        0    1     1
                        1    0      1
                        1     1      0
vead
Nov 27, 2011
473
please some one check out this table. and tell me its correct or wrong ?
I read in every blog that processor made with ALU and control unit. so after some reading I made this table. i am not going to make for company. I am just going to make specific one for my basic understanding
I think the problem is that you don't understand what an ALU is or does.
The big hint is that it doesn't perform just a single function.
14,306
Maybe a video is beter than reading stuff?
Sorry, I don't have the time to check the full function table. As these are basic functions, you should be able to verify by yourself.
vead
Nov 27, 2011
473
I already mention function for ALU in my previous post
ok look at this
ALU perform following function
AND logic
OR logic
NAND logic
NOR logic
X or logic
X nor logic
addition
subtraction
14,306
If you design so, yes.
You don't necessarily have to design an ALU this way. ALU stands for Arithmetic Logic Unit. Which means it is a unit that can perform arithmetic and logic operations on its inputs and generate an output accordingly. You can use the functions as indicated by your table, bt as a designer you are free to chose any set of functions that is suitable for the purpose which can be very different from your table. This is your own design decision.
vead
Nov 27, 2011
473
thanks for looking
thanks for looking this post
4 bit processor
component for 4 bit processor
1)4 bit ALU
2)3:8 decoder
now If I want to make 8 bit processor then I think I need following things ( I am not sure ?
1)8 bit ALU
2)3:8 decoder
