robb
- Jan 1, 1970
- 0
it is a connector device that you clip/solder on the edge of a
pcb that looks like an IC pin when your are done... but it is on
the edge of a PCB
what i am trying to do is create another PCB DIP 40 adapter for
a smaller SMT/SMD chip package. the PCB will have traces on one
side for the SMD chip where pin traces lead to the pads along the
edge of PCB to accomodate these pin connectors.
The PCB part will be cut to the size of a DIP 40 device
(obviously. ? ) so with ??pins installed?? look like a
Franken-DIP-40 with a SMD chip piggy back
the **space is very tight ** and i also want sturdy pin
connectors. I have seen these used somewhere but can not figure
where so as to show an example
thanks for any help,
robb
the edge of a PCB
robb
