Nand Gate oscillator help
Gryd3
Jun 25, 2014
4,098
@IC71 your very welcome!
I take it you don't need that picture ;)
All it takes is a brief oversight or misunderstanding. Even if you understand how it should be connected, the tiniest alteration can make a big difference.
Enjoy playing, and by all means, if you have another questions let us know!
IC71
Sep 8, 2014
20
Hello again.
I got such awesome help last time..... so I'm back again! I am having another problem with my circuit.
I am on lesson 29: Using Transistors to Amplify the Output of the "Electronic Circuits for the Evil Genius book", and like the title said, I have to use a PNP transistor to amplify the volume of the output of the circuit.
I replaced the LED with a speaker, my 2.2 m resistor with a 22 k resistor, and my 0.1 μF capacitor with a 0.01 μF capacitor.
the book told me to rewire my circuit to include the PNP 3906 transistor. It said that it would make the sound from the speaker louder, but I don't hear any difference in volume. Do I have the transistor plugged in correctly? If not, how does the transistor fit in? IMG_2611.JPG
IMG_2608.JPG IMG_2608.JPG IMG_2609.JPG IMG_2610.JPG IMG_2611.JPG IMG_2605.JPG IMG_2606.JPG IMG_2607.JPG
Gryd3
Jun 25, 2014
4,098
Yes, it is wired incorrectly ;)
Let me ask you this. On your diagram.
What should the + for your speaker be connected to?
What should the - for your speaker be connected to?
IC71
Sep 8, 2014
20
+ should be connected to leg E and - is connected to.... leg C?.... leg B? I know leg B is connected to pin 10, but the black wire was connected to pin 10 before the PNP... uh... I don't know, the schematic looks like C is connected to Ground? Should the black wire connect to leg C, and do I remove the yellow wire connected to the + wire?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
One side of the speaker (the red wire) is connected to the emitter of the transistor. That's right. Where should the other side of the speaker be connected to?
Also there is a yellow link wire from the emitter of the transistor to one of the power supply rails. It shouldn't be there.
You may have damaged the transistor. You may have to replace it.
Gryd3
Jun 25, 2014
4,098
In the diagram, I see the Speaker + being connected to the + power rail.
The Speaker - is connected to leg E. That takes care of the speaker... Just need to doublecheck the transistor.
leg B should be connected to pin 10 and NOTHING else ;P
leg E should be connected to the - of the speaker and nothing else.
leg C goes right to ground.
This is the important page to me: https://www.electronicspoint.com/attachments/img_2609-jpg.15379/
IC71
Sep 8, 2014
20
Gryd3
Jun 25, 2014
4,098
Looking much better now.
If it does not work, you may need to replace the transistor... hooking it up the way it was before may have damaged it.
What will happen now, is the Nand gate will trigger the transistor. The transistor can handle more power, so the way it's hooked up should allow for a louder speaker.
IC71
Sep 8, 2014
20
Thank you so much... again! This was really helpful
Gryd3
Jun 25, 2014
4,098
Not a problem.
You'll get used to it, You keep over complicating the schematics I think and think what might be connected through other things.
IC71
Sep 8, 2014
20
Hello again
I had just built a circuit and I am having a very difficult time trying to ID the current problem with it. It is suppose to turn on with the touch switch and get turned off by the other touch switch. Instead, it turns on when I touch the first switch, and then turns of immediately after I let go! I don't know whats happening? I think i have every thing in the right place, and it does not look like the solder is connecting any unwanted wires, I just don't know whats wrong?
IMG_2925.JPG IMG_2926.JPG IMG_3011.JPG IMG_3012.JPG IMG_3013.JPG IMG_3016.JPG
KrisBlueNZ
Nov 28, 2011
8,393
Those aren't schematics. The second picture in post #22 is a schematic.
Arouse1973
Adam
Dec 18, 2013
5,178
Isn't the schematic in post #22? But looks like a switch has been connected instead of R2. What diode is used for D1? and what size capacitor for C1?
Adam
KrisBlueNZ
Nov 28, 2011
8,393
Not according to his description of what the circuit is supposed to do, in post #31.
IC71
Sep 8, 2014
20
Adam
C1 is a 1μF, D1 is a signal diode (skinny gold) and here is my schematicIMG_1198.JPG
IC71
Sep 8, 2014
20
The only modification I made was the touch switches. It worked perfectly on the breadboard, but I started to have the problem after I soldered the parts into the PBC. My electronics teacher just replied to my question saying that the IC, D1, and/or transistor could have been damaged by the heat of the soldering iron.
KrisBlueNZ
Nov 28, 2011
8,393
That circuit isn't going to do what you want. If the contacts drawn next to C1 are a touch switch, they won't do anything because that node in the circuit is driven by pin 11 of the IC. The behaviour you'll get is that when you touch the left hand contacts, the oscillator will run, and when you release them, it will stop. C1 will have no effect.
You can get the behaviour you want. I'll post a diagram shortly.
